Question about Sharper Image Audio Players & Recorders
Sharp Model SPC033 gains 4 hours. Runs too fast.
AC 110 v 60 Hz 2W. Swivel base. Digitil red lettering. Runs too fast. How can I solve the problem?
2 Suggested Answers
Bogdan
  • 198 Answers
SOURCE: My digital alarm clock is fast
I'm not on this field of expertise but I could try giving you some tips. These cloks work by dividing the natural oscilations of a quartz cristal in the corresponding way to form "1 second". A quartz cristal like the one in your clock will oscilate at about 14080236 times per second. Your clock uses a specialised chip in order to count these oscilations and know they form "1 second". However, the problem is the following. These clocks doesn't compensate for frequency variation over the mains power line. You should always look firts at it's power ratings and determine if it requires 50Hz or 60Hz. Even if you use an adaptor to raise/lower the tension from 110 to 220 v or viceversa, this woun't correct the problem as the adaptor will leave the frequency unchanged. Unfortunately in order to make the required adjustments you woun't need a resistor or capacitor, but a whole bunch of them in order to make a frequency divider-convertor that's stable enough to give your clock a fixed time reference. One more thing, not all components have exactly the parameters noted on them. There's another thing called Tolerance. A 1Kilo Ohm resistor with 10% tolerance (most comon tolerance) can have any value with +/- 10% of it's noted parameters, and in this example, could have any value between 900 ohm - 1100 ohm. These clocks will need components with a very strict tolerance in order to have an acurate time reference. Note that they aren't atomic clocks, they simply use a larger chip that includes most of the clock, time reference, frequency analyser and divider. An atomic clock doesn't use quartz cristals, instead it relies on the natural oscilations of the very precise Cesium izotope atom. The rest of the atomic clock is made up in a similar way as usual clocks (more fixed and small tolerance of course :) ).
Posted on Jul 02, 2007
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
Why do my clocks run fast when my Briggs & Stratton 15kw generator is running?
Electric clocks use synchronized motors that run on 60 Hz AC. The power company provides AC power with a precisely regulated frequency of 60 Hz. That means that the voltage jumps back and forth (positive to negative) 60 times per second. Your generator would do the same thing if it could run at precisely 3600 rpm (that's rev's per minute) - but it can't, because the engine is not that precisely controlled. In your case it tends to run (on average) a little fast. I hope you found this helpful. By the way, in Europe 50 Hz is the norm. If you run a clock designed for 50 Hz on 60 Hz power, it will run 20% too fast! Al K
Jun 20, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
I am trying to connect my sharp liquid crystal tv LC26SH10U, to my laptop and am unable to do it, I wanna use this tv as a monitor.
I have this same model TV & am using it as a second computer monitor. I have mine running through an HDMI connection on input 4. I will mention it runs at 1280x720 recommended. I'm not sure if it's the display or just my video card, but mine can handle UP TO 1920x1080. Something to note, however, is that the TV has a natural refresh rate of 60 Hz. Check your video settings that they can handle that (or at least an even integer thereof). My card (ATI HD 5750) is running it at 30 Hz with some minor issues.
Final point: if you want the sound to pump out of your TV as well, remember to change the default sound device in your volume control panel.
Oct 25, 2010 | Sharp LC-26SH10U 26 in. LCD Television
Clock not keeping the correct time
I have to ask where you bought the unit? Did it just start doing this or has it done this since new? The reason I ask is if you have a 50 Hz unit and it is operating on 60 Hz it will gain time and there is no adjustment.
Mar 06, 2010 | Miele H344-2 B Stainless Steel Electric...
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
Breitling problem
This usually occur when the hairspring is disturbed ( some grease, dust particle, etc). Can be magnetized as well.
You need to find your nearest watch repairer and ask to overhaul your watch. After that it will run like new.
Jan 03, 2009 | Watches
Honeywell Ceramic Heater (HZ-370) does not swivel anymore
The instructions say this unit is not designed to be taken apart and they are right. Although i was able to unscrew the back plate and slip my hand into wipe the swivel base. It turns once again and my wife thinks I'm a genius.
Dec 21, 2008 | Honeywell HZ-370 Ceramic Heater
LG swivel base
Just look at where the base goes in. There should be 4 screws that are holding it on.
Apr 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Need to Upgrade Hard Drive & Memory for Sharp PC-UM10M
SHARP PC-UM10 SPECIFICATIONS
CPU Ultra Low Voltage Mobile Intel® Pentium® III processor 600 MHz-M Memory 128 MB SDRAM, not expandable (model PC-UM10) 256 MB SDRAM (model PC-UM10M) Video ATI Rage Mobility M (including 4 MB video RAM) Display 12.1" XGA AGLR TFT LCD (1024 x 768) Hard Drive 20 GB Pointing Device Glide pad (touch-sensitive control pad with 2 buttons) PCMCIA 2.1 Card Slots Type II x 1, CardBus port supported Audio System Monaural microphone and monaural speaker, sound system compliant with AC 97 I/O Ports USB, LAN, modem, headphone, microphone, DC in, expansion port for port bar Modem 56Kbps (V.90) LAN 100Base-TX/10Base-T AC Adapter 100-240V, 50-60 Hz Battery Rechargeable lithium ion battery Battery Life Standard battery - approx. 3 hours. Optional extended life battery (CE-BL18) - approx. 9 hours. Battery life is based on ZD Battery Mark 4.01. Battery life may vary based on actual usage. Dimensions 11.1" x 9.1" x 0.65" (min)/0.77" (max), 282mm x 232mm x 16.6mm (min)/19.6mm (max) Weight 2.89 lbs., 1.31 Kg Operating System Microsoft® Windows® 2000 Operating Environment Temperature: 50°F to 95°F (10°C to 35°C) Humidity: 20% to 80% (non-condensation) Power Consumption Max. 40W Available Options Extended Life Battery CE-BL18 Optional longer life battery 6X CD-ROM Drive CE-CD05 External USB CD-ROM Floppy Drive CE-FD04 External USB Floppy Drive Port Bar CE-PB01 Provides additional I/O ports
Design and specifications are subject to change without prior notice. Some options may not be available in some regions.
[HOME] [NOTEBOOKS]
Oct 22, 2007 | Sharp PC UM10M Notebook
284 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
