Question about Drills
Bosch hammer drill 11232evs need manual - Drills
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: my drill bit doesn't remain secure in the chuck of my drill.
grind bits shank in a triangle to let the drill chuck get a better hold of bit but be carfule because this also takes away the drills ability to slip if it hits something solid.
Posted on Apr 15, 2009
smjdragonfly
  • 79 Answers
SOURCE: Hammer drill will not hammer.
Need a new clutch/tranny. You can find it online - look up tool parts on Google. Tool Parts Direct is a good source. Please rate me
Posted on Jun 18, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
How to chisel
The Bosch 1199VSR Hammer Drill is capable of drilling or hammer drilling at two different speeds but can not hammer or chisel only. To do that you need a demolition hammer or roto/demo hammer tool.
Jan 28, 2012 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
I bought a used Bosch Bulldog hammer drill on the internet some time ago and discovered it's not hammering. It will drill be almost no hammer action. Any suggestions?
There is an o-ring on the striker that will wear down over time, this needs to be changed, of worst case the striker has stuck in the hammer piston. Both these repairs should really be done by a service center as these hammer drills are complicated to repair if you are not familiar with them. Any Bosch service center will be able to help you. Just go to the Bosch website and find a center in your area.
Jun 08, 2011 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
New bosch psb 550 re with hammer action. Hammer action does not seem to engage. even with 5mm bit progress is non existent. The bits were bosch masonary bits and I was drilling into concrete blocks
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Oct 09, 2009 | Bosch Power Tools Hammer Drills
Bosch - Rotary Hammer Model 11232EVS
This site does not have the manual for the exact model number you are seeking but several that are similar and may be helpful:
http://powertool.manualsonline.com/ex/thread/view/idThread/76898
Sep 03, 2009 | Tools & Hardware - Others
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Drills Logo
26 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
