Question about Fujitsu AMILO D-8830 Notebook
How to open keyboard
I have brought fujjitsu siemens amillo d 8830 now my keyboard is mallfunctioning I want to open keyboard and clean keyboard Please can you help me how to open keyboard regards manju
This sounds like what I need but where is the image?
Posted on Dec 14, 2012
The (Norwegian) keyboard on the D8830 which I've recently serviced, is held in place by 3 spring loaded metal tabs (see red arrow in attached image) located above the F1, F8 and Num lock keys. 4 more tabs below the Fn, Space, "right-click menu" and right arrow keys are inserted from the keyboard backplate into slots in the laptop chassis. To remove the keyboard you need two small slotted (flat) screwdrivers (or similar equipment). Always remember to disconnect the AC-adapter from the laptop and remove any electrostatic charge from your body before handling computer parts. 1) Carefully insert one screwdriver between F1 and the leftmost metal tab (red arrow). 2) Gently push the tab away from the keyboard by tilting the screwdriver towards the keyboard. 3) Insert the second screwdriver between the keyboard backplate and the chassis (yellow arrow). PS! Make sure the screwdriver gets hold of the backplate, and NOT the ESC key. 4) The tricky part is using the second screwdriver to tilt the upper rightmost part of the backplate above the first tab so that you can use the first screwdriver on the next spring loaded tab. With some patience and a few (or many) attempts you'll succeed. 5) Continue with the remaining uppermost tabs by repeating the procedure in steps 1-2 and use the second screwdriver (or your fingers) to tilt the backplate further away. PS! The backplate should only be tilted above the tabs until it is released from the third tab (above the Num lock key). 6) Tilt the keyboard approx 30 degrees and slide it towards the screen to release the lowermost tabs from the slots in the chassis. If the keyboard is stuck, try gently rocking it from side to side. 7) Tilt the keyboard 90 degrees and disconnect the flat cable which runs from the keyboard into the chassis. Hope this helps. As with most computer parts, brute force is seldom a good solution. :-) Regards, Palsam
Posted on Jul 05, 2007
  • 883 Answers
Look for a thin piece of plastic strip that runs the full width of the keyboard near its top. Pry this off gently starting with a jewelers screwdriver (careful not to score plastic). after this is out, lift the keyboard out and disconnect the electric flex circuit.
Posted on Jun 09, 2007
No WLAN after installing Windows 7 on the Fujitsu/Siemens Amillo L
You need the network driver for your WLAN card for Windows 7. Most manufacturers have not updated their drivers yet, and Siemens would be among them.....
Jan 07, 2010 | Fujitsu AMILO PC Laptops
Amillo pro 2010 screens gone black tried new inverter still no good cleaned ram no good the xp pro disc is off this laptop but got invalid message when reinstalled the screen went blank two days later cant...
Try useing external monitor?
Dumb Question.
Try switch monitor button? Fn + F5 (together) usually
Hard way,
Remove hard drive, maybe even CD Reader, Floppy.
Power on system
Oct 02, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Lost install disk amillo pro v2055
You will either have to find it or buy another
They are your only options
Sorry
Sep 22, 2009 | Fujitsu Siemens Computers & Internet
DVD burning on Seimens Li Amillo Laptop
When you are finished burning a disk you have to make sure you finalize the disk.
Nov 28, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Restore factory settings on a fujitsu siemens amillo pro
You should be able to fix this simply by inserting the original Cd that came with the computer and following the onscreen instructions.
Or the startup disks (if created) when you first used your laptop.
Alternatively If you do not have the one that came with your computer then you should be able to purchase one from ebay quite easily, and then insert it and follow the onscreen instructions.
I hope this helps you, Chris
Nov 03, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Upgrading memory
I have found a link for you from where you can download the mannual for the notebook you are using. This mannual explains that how you can replace the memory of the notebook.
Open link
http://www.fujitsu-siemens.com/support/manuals.html
Under "Select Product" - Select Notebook - Amillo Pro - Amillo Pro V2xxx - Amillo Prov 2000
Download and open
Basic informations on mainboard Technical Mannual
You will find the details in that.
I hope that this resolves your issue.
Sammy
Nov 28, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu AMILO D-8830 Notebook Logo
320 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
