Question about Crosley Washing Machines
Crosley washer model CW22B6V will not spin - Crosley Washing Machines
3 Suggested Answers
  • 3741 Answers
SOURCE: Washer wont agitate.
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on May 05, 2009
  • 47 Answers
SOURCE: Washer did not spin
JERRY,
IT SOUNDS LIKE YOU GOT TAKEN ON THIS WASHER. A NEW WASHER NORMALY WORKS, BUT IN SOME INSTANCES, LIKE YOUR CASE, IT COULD BE THE BELT OR THE MOTOR COUPLING. WHAT I WOULD DO IS CALL THE PLACE WHERE YOU GOT YOUR WASHER FROM AND HAVE THEM TO BRING YOU A NEW REPLACEMENT. THERE HAVE BEEN COMPLAINTS ABOUT WASHING MACHINES NOT WORKING RIGHT WHEN THEY WERE NEW. I HOPE THIS HELPS YOU AND ANYBODY ELSE WHO READS THIS WEBSIT, BECAUSE THERE IS NO SENSE IN THE STORE SELLING A BRAND NEW WASHER WHEN IT ALREADY LEAKS.
RODNEY
Posted on May 14, 2009
Can I bypass the lidlock switch on a Crosley topload washer model caw9244xq4
No you cannot. The troubleshooting on this model is intense and takes hours if done as per the manual. If you are having problems with the door lock or it isn't spinning out properly, it has been my experience that the shift lock actuator (W10006355) is bad.
Aug 29, 2017 | Crosley Washing Machines
Spin light is blinking on my crosley washer
check belt is not Brocken filter is cleaned also can be the motor not turning check brushes or that the motor is not burned
Aug 13, 2014 | Crosley caw9244xq 3.4 cubic foot white...
Our Crosley washing machine (Model # CW5000W) will not spin all the water out of the clothes and is making a bad noise while it spins.
Three possibilities here,
One, you've overloaded the washer with clothes, throwing the washer basket on tilt because of the extra weight and force against the agitator. Remove the wet clothes from the washer and try continuing the cycle.
Two, One of the elastic/spring arms that centers the basket inside the washer housing has broken and is allowing the basket to simply flop around. Disassemble the washer and inspect the basket supports.
Three, The center post that the washer basket sits on is going bad - The most common reason is that the bearings have gone bad. Disassemble the washer and replace the bearings at the base of the basket where it connects to the motor.
May 04, 2011 | Crosley Washing Machines
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Washer did not spin
JERRY,
RODNEY
May 14, 2009 | Crosley CAWS729MQ 3.2 cu. ft. Washer
Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Oct 12, 2007 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
