Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
I have a titan 9000ES generator with the 11 hp motor; sometimes it will run for hours - other times it starts to die; catches; dies catches; dies. Usually starts right up, but die again. I replaced
The problem seems to be worse when the air temperature is 50 degrees or above.
  • 152 Answers
SOURCE: Almost new McCulloch 7800 won't start.
This is a typical problem with small engines that are not used often or only used seasonally
The problem exist when it is not prepped for storage properly, meaning that the fuel is not shut off and the engine allowed to burn off the remaining fuel that's left in the carburetors float bowl, causing the un-spent fuel to sour and later creating a condition called varnishing which clogs the carburetor venteries
All of these steps will require the use of skin and eye protection!!!
The solution is to replace the old fuel in the tank with fresh, its not a bad idea to replace the fuel filter at this time, then with the petcock in the off position remove the carburetor float bowl, inspect the gasket or seal for imperfections (replace as needed) and clean it along with the float assy. and piston check valve with a spray type carburetor & choke cleaner and gently wiping with a clean lint free cloth so as to remove all yellowish colored varnish and any debris, before reassembly place a glass or metal catch pan or bowl under the carburetor and turn the petcock to the on position to allow fresh fuel to flush out the fuel line and now LIGHTLY & GENTLY (without resistence) lift the float up, the fuel should stop flowing. If it does not stop, repeat cleaning procedure. If it does turn the petcock to off and reassemble. After reassembly turn the petcock to on, the engine should run.
Another preventive step is the use of a product called STA-BIL fuel stabilizer
Posted on Feb 20, 2009
mamicheddy
  • 79 Answers
SOURCE: McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Posted on May 09, 2009
SOURCE: McCulloch 11HP FG6000MK surging
I just came across this post. Hopefully you have it solved. But for others who may run into this problem here is my advice. This model has a low oil sensing system. Over time the oil breaks down or gets contaminated. This can cause sympoms very akin to carb issues. I'd check this 1st as its the easiest fix. Drain and replace oil to the factory recommended specs. Make sure it is to the proper level. Your not finding any carb issues makes this almost a sure thing. DO NOT DISCONNECT or DISABLE the sensor or you defeat its purpose.
Posted on Jan 12, 2010
SOURCE: McCulloch generator stops after about a minute
Have Generator McCullough FG 6000 was running fine motor still running fine than NO power output, any suggestions ?? Can you get replacement parts and repair diagram off the interent ??
Posted on Jul 12, 2010
SOURCE: my 5700 watt 11 HP McCullough generator wont
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Posted on Oct 26, 2010
2001 explorer sport , fuel pump? vacuum leak? 619 scan tool data provided, any suggestions/solutions
The fuel pump is suspect but I believe there's also a fuel filter inline on the underside of the drivers side chassis. Fuel works off pressure so if the filter is clogged, the pressure remains between the fuel tank and the filter. Once the fuel has siphoned off between the filter and injectors, it dies but because there's positive pressure at the fuel pump, it won't come on until the pressure slowly seeps past the clog after hours. It's worth a look!
Apr 08, 2017 | 2001 Ford Explorer Sport Trac
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
My generator is a briggs and stratton 7kw prowered. connected to full propane tanks. i have not had any problems with the generator until this past weekend. the generator starts up fine, and then once...
You have a fuel delivery issue that can be dealt with by cleaning carb or replacing it. If you do replace carb has to be adjusted to the motor.(idle, mixture)
Sep 03, 2017 | Briggs & Stratton Briggs Stratton 7 kW...
Bought a used 2006 Nissan Titan with a 1 year old Continental battery. Drove it for 4 days, was cleaning it out with all windows down and doors open. Tried to crank it. Wouldn't start and wouldn;t allow...
2006 NISSAN TITAN ELECTRICAL SYSTEM:BATTERY
Occurences: 1 NISSAN NORTH AMERICA, INC.
Recived: 2007-09-20 Summary: 2006 NISSAN TITAN BATTERY DIED WHILE DRIVING. CUSTOMER STATED THAT HE HAD NO PRIOR INDICATIONS BEFORE THE FAILURE. HE ASKED TO BE REIMBURSED FOR THE BATTERY . *KB THE CONSUMER STATED A BATTERY... The following ELECTRICAL SYSTEM:BATTERY complaint about 2006 NISSAN TITAN was reported to the National Highway Traffic Safety administration on 2007-09-20. For more information contact the National Highway Traffic Safety administration or the US Department of Transportation. See complaint summary below.
Build Years/Makes/Models: 2006 NISSAN TITAN
Occurances:
Reference Number: 10203844
Summary: 2006 NISSAN TITAN BATTERY DIED WHILE DRIVING. CUSTOMER STATED THAT HE HAD NO PRIOR INDICATIONS BEFORE THE FAILURE. HE ASKED TO BE REIMBURSED FOR THE BATTERY . *KB THE CONSUMER STATED A BATTERY SHOULD LAST MORE THAN 11 MONTHS. *JB
Occurances:
2006 NISSAN TITAN
Occurances:
2006 NISSAN TITAN
Occurances:
CHECK WITH ANY DEALERSHIP AND GIVE THEM THE VIN NUMBER AND ASK IF THERE ARE ANY TSB'S FOR THIS VEHICLE IF THERE ARE THERE WILL BE FIXED AT NO COST TO YOU
Apr 14, 2011 | 2006 Nissan Titan
McCulloch 5700, 11 HP Starts easy with 2 pulls and begins running fine. Then it start dying and back fires,revs up and down, back fires. Then will run normal for a few minutes and will start revving up...
Sounds like you may have a wire shorting out. Check all ign wires and make sure one hasnt rubbed through. Maybe take off your front cover and make sure something isnt shorting out your coil contacts. Hope this helps
Nov 02, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Porter/Cable BS1525-w generator, starts always on the first pull, runs fine for an hour or more and then it dies out. Starts right away and it runs again for a while before it dies out again. No matter if...
Hello. I'm sure that you've checked your air filter, so check the pinhole vent on the fuel filler cap. Next time it dies, immediately crack the cap and listen for the sucking sound of air rushing into the tank. If you hear this, clean the cap!
Regards, --W/D--
Jul 23, 2009 | Porter Cable 3,500 Watt 6.5 Hp Portable...
Mcculloch generator 5700W 11 hp
Sounds like your choke is not closed correctly when you first start the genset. Remove the air filter and look at the throttle plate. It should be closed with a hair line gap. With your finger you should feel very little play on the throttle plate. As you open the choke, you should be able to open it all the way once the engine has reached a hotter temperature. If the engine is still cold and your opening the choke all the way, it will try to die out.
Feb 09, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Propane-converted generator sometimes sputters out and dies
I believe the problem may be with the propane. Have him call his propane provider and get them involved. good luck
Dec 26, 2008 | Coleman Powermate Premium Plus 6250W...
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
53 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
