Question about Garmin GPSMAP 2006C GPS Receiver
Connecting uniden 625 vhf radio to garmin 2006c chartplotter
Radio has cable with connector to radio. only bare wires to GPS. Need to know where and how they connect to gps
  • 13433 Answers
SOURCE: Garmin GPS GSMAP 182C Chartplotter will not boot up
If the unit doesn't go further from the reading card. this may indicate that theres a problem in the memory card.
Not being able to a get a signal lock on satellites would indicate a problem either in the software something is wrong or not geting loaded correctly (the memory card) Or a hardware problem.
You may have to take it in for service if you are unable to check the memory card or replace it.
Posted on Jun 27, 2008
SOURCE: ANTENNA UNIDEN MYSTIC
Good News!!  I just received the email from Jessica at Uniden but when I called to place the order, I learned they are back-ordered( 550 Units) and are not scheduled to arrive until Nov 28, 2008.
So hopefully we will get them.  There is a $10 shipping charge in addition to the antenna.
L Meier
Larry,
Thank you for your inquire. I apologies for the information you may haven been given. But You are able to order the antenna for this model. They part your needing is part number BATY0461001 Cost is 27.16. This part is on back order. If the jack that the antenna screws on to is also damaged you most likely can buy this part but there are no instructions on how to install it.
To send the unit in due to the jack being the damaged part. You would be asked to box the unit up attaching a note explaining the problems your having along with a check or money order for the flat rate repair fee of 59.95. This amount includes all parts labor and return shipping. The unit will then carry a 90 day warranty.
Posted on Aug 01, 2008
  • 3 Answers
SOURCE: Uniden mystic handheld VHF+GPS
If you are still looking, I found some here http://www.pafinimarine.com/Outdoor-amp-Seasonal/Cordless-Phone-c62/
or you can also search from their homepage under Outdoor & Seasonal Items www.pafinimarine.com
Enjoy!!!
Posted on Oct 03, 2008
SOURCE: chartplotter (Garmin 450s) won't talk to VHF DSC radio (Icom IC M
As advised, reset to factory settings. Then re-entered custom settings as required. Seems OK now. Many thanks.
David Godfrey
Posted on Jun 22, 2009
  • 59 Answers
SOURCE: can the Garmin 126 Marine GPS be hooked into a VHF radio emergenc
The comprehensive PDF on the Garmin site here:
http://www8.garmin.com/support/faqs/faq.jsp?faq=68
may help.
Posted on Sep 04, 2009
I have a uniden vhf radio that transmits but won't receive
send it for repair
Uniden - Online Repair Form - Uniden Repair Center - Uniden Americahttps://repair.uniden.com/repairInstruct.cfmRepair Procedure -Brand New Products. Marine Radios=3yr Warranty, Scanner Radios=1yr Warranty. GPS System=1yr Warranty, Digital Camera=1yr. Warranty.
uniden vhf radio Google Search
Jun 24, 2017 | Uniden Radio Communications
How do I connect a uniden vhf radio to my trackfish 6600
Hi Gil!
Easy peasy.
From your 6600, the data sends are the white wire NMEA (+) and the black wire (-). There are two black wires. Doesn't matter which one you use as they're interconnected anyway.
To your UM425, the green wire is NMEA in and the bare wire is ground.
So...
white from 6600 to green and
black from 6600 to bare.
Hope this helps you out.
-Steve
Jan 09, 2015 | Uniden Boating
How to wire Uniden UM380 to Garmin 2010c for gps reading on radio
Garmins have USB or Data connectors - or both
obviously radio needs one of those inputs.
radio must be setable for Garmin format. If NMEA only verify Garmin is set to output NMEA - some do not have that option.
Aug 25, 2014 | Uniden UM380 Fixed Mount VHF Radio, White
Hello, Can you tell me what make of GPS will work with the Icom m-504. I tried using the Garmin 76csx with the NEMA in/Nema out function set, but it will not communicate to the Icom. I would appreciate...
Hi!
We had the same problem with our Uniden Oceanus failing to communicate with our GPS. What the problem was, was that our VHF didn't recognize the NMEA sentences transmitted from our "ancient" GPS. We ended up buying a Standard Horizon cp180 chartplotter. PRESTO! Our DSC capability materialized.
Your 76CSx is newer than our Magellan was, so before you take on the task of a $400 chartplotter purchase, just make sure your BAUD rate is set to 4800. This adjustment alone could make your GPS work with your ICOM.
Hope this is helpful.
Jan 23, 2011 | Icom IC M504 Black Submersible PLUS Marine...
Connecting Garmin GPS 152 to VHF Radio Silva S15
Hi!
From the S15 owners manual (Page 46):
http://www.bluemoment.com/manuals/silva_s15.pdf
The RED wire is GPS data,
The green wire is GPS ground.
Hope this helps and good luck!
May 08, 2010 | GPS
I'm after the wiring diagram to connect a Garmin GPS17N to a Uniden Oceanus. Any ideas?
You wanted to charge me to provide a solution but now that I've found that solution, will you pay me to give it to you?
Feb 07, 2010 | Uniden Oceanus VHF DSC Radio White
I press dsc and see no change on the screen
Many VHFs will not acknowledge any of the DSC functions if the unit is not receiving position data. If the unit is correctly wired to a GPS or chartplotter and you can verify that it is receiving position information, then you may have a faulty radio.
Aug 08, 2009 | Uniden Solara DSC VHF Marine Radio
Chartplotter (Garmin 450s) won't talk to VHF DSC radio (Icom IC M
David Godfrey
Jun 16, 2009 | Garmin GPS
I have a Simrad CP32 mk2 chartplotter ,when VHF radio is switched to channel 10 no communication is possible due to heavy interference. Even a hand held radio independent of all electrical connections has...
I have a Garmin 182C and I get interfernce on VHF channels 21,22 and 83 the moment I turn on the Garmin. I have tried changing radios, antennas, placed separate poer and aground lines and nothing helps. Garmin gives me the run around.
Feb 23, 2009 | Boating
Garmin GPSMAP 2006C GPS Receiver Logo
132 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
