Question about Duravit Starck 3 Wall Mounted Toilet with Carrier
Running water in Geberit Starck Toilet
Since a couple of days ago, post-flush, the water in my Geberit Starck wall mounted toilet keeps running after filling up. It is quiet while filling up, then starts running all day.
I have tried the "pull button" that is reached from underneath, to no avail.
How do I stop the running water? How do I open the push plate to access the tank without damaging the wall?
  • 34 Answers
I hate to say it but you may need a pro on this one, if you want I can try to walk you threw it but let me know. bigslimaba@yahoo.com
Posted on Feb 05, 2009
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
My geberit model number 131.028 dual flush won't shut off with water and leaks into the toilet bowl
How old? Who installed? Any warranty? I'd follow that route first.
If not warranty I'd try to get the installer to be interested. Perhaps he will have a "red face" an help out.
Feb 27, 2015 | Geberit 131.028.SJ.1 Black Glass Monolith...
Geberit model 150-403 toilet Water keeps running after flushing
I have the same problem with my new Gerberit 800 plus fitted last Thursday, it will not stop flushing in the manual it says valve problem contact service dept. Joke they dont give a number for them.
Feb 02, 2013 | Home
My w/c flush non stop water flow
You need to shorten the flush time of the flush valve.
Aug 23, 2011 | Duravit 111335001 Geberit In Wall Carrier...
Water level in bowl is too low so it's a problem keeping it clean. How can I raise the water level?
All toilet bowls have a preset water level determined buy the design of the internal s-trap and can not be change. However if the water level in the tank is not as high as it should be this will affect the water put into the bowel as the bowel in refilled by the flush valve and if it is set to stop before it get filled to the proper setting the bowl water level may be low.
A quick test is to see if the water level in the tank is up to the line in the tank most all toilet tanks have a line either stenciled or marked with a indentation in the porcelain. Another way is to mark the level in the bowel with tape or a marker then pour water slowly into the bowel not fast enough to flush it wait to see if it stays higher then the mark you made or settles back to that level.
Feb 04, 2011 | Duravit 111335001 Geberit In Wall Carrier...
My geberit in-wall toilet won't stop running, and there is no way to access any type of plumbing fixtures to fix. Please help me!
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
Nov 29, 2010 | Duravit 111335001 Geberit In Wall Carrier...
My toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Oct 17, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Duravit Starck 3 Wall Mounted Toilet with Carrier Logo
4,488 people viewed this question
Top Duravit Home Experts
Paul Carew
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Duravit Home Expert? Answer questions, earn points and help others
