I lost my maual for my Motorola H350 headset and I can't set it up properly (voice calls, ringing tone changes etc..) does anybody know of a website that I can download a manual or instructions from? The Motorola website is useless... Thanks. Tripple M
User Manual for the Motorola H350 Bluetooth headset!
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H350_QSG.pdf
Here is a copy of the manual for settung up th Motorola Bluetooth H300 .... passkey is 0000
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
Http://www.motorola.com/staticfiles/Support/Mobile%20Phones%20Accessories/H350/US-EN/_Documents/Static%20Files/H350_QSG.pdf this link should solve everyones problems with the h350. also all passkeys are 0000. hope this helps
Heres the Moto pdf link to download the manual...
Thank You Everyone for your Help! I entered code 0000 and it worked, you have to enter the code 2 or three times, first when you pair it, then again when you set it up as a hands-free handset, Thanks Again -Turtle13131
Here is the link for the quick start manual.
Just copy and past that into the address bar.
The number to pair is 0000
Hope this helps,
Ace
Http://www.motorola.com/consumer/v/index.jsp?vgnextoid=5398e7ff7e35a010VgnVCM1000008206b00aRCRD&show=support&catName=9f8b1787c85c9010VgnVCM1000008206b00aRCRD&product=c1df9f85dc575110VgnVCM1000008206b00aRCRD&category=692c4b90ca614110VgnVCM1000008206b00a____
From there select accessories, then the devise H350 half way down then go
If you have the H300 bluetooth, try this manual http://www.mobilefun.co.uk/download/manuals/h300manual.pdf you have to put it in pair mode. basically with the device turned off, press and hold the pwer button until the blue light remains steadily lit. then you can search for the device from your phone. the passkey should be 0000. good luck.
Hi
Click on this link: Click Here
Please remember to rate this solution as FixYa!
Kind regards
BearWeb
0000 (zeros-not letters)
My speaker doesnt work on my H300 bluetooth headset what do i do
Hi, go to http://manualfox.com and ask them. It´s an international manual search agency which finds you virtually every manual on earth.
Http://safemanuals.com/user-guide-instructions-owner-manual/MOTOROLA/H350-_P
I used 0000
Bought a new phone and trying to set up blue tooth hade for three years cant find paper work with the code on it. Motorola H350
Trying to set my earpeice to be aboe to link it with my phone but dont remember how to do it.
I need the code to lock my h350 to my phone.
thks
I dont know my bluetooth passcode to my motorola phone it changed on its on
Thank you very helpful!!
First of all, I had the same problem and went to the Motorola site. I did a search on "H350 Motorola Headset passkey" and it came up with a line that said the key was 0000 and cannot be changed.
This site has the manual (does not have a PDF to dowload but can read the instructions there at least) for the H3, the manual looks virtually the same from what I can remember (I lost mine too!) and the instructions seem to work for what you'll need.
If anybody is using this for the HS850 then the light does not stay steadily lit. To do this you must open the headset while the light is on. Then it will pair with the 0000 passcode.
Http: //manualshark.org/manualshark/files/25/pdf_19516.pdf
SOURCE: maual for Motorola H350 bluetooth headset
This may help. Click the link:
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/AU-EN/H350_User_Manual_19oct2007.pdf
Ignore the chinese as you go. Its like mixed together but you'll find what you need. Good day!
Please vote.......
Thank you. Thank you. Thank you. I thought I was going to have a bluetooth that I couldn't use because I had purchased a new phone and lost my bluetooth manual. I went to the Radio Shack website and went right to the manual. It took about 2 minutes to pair it with my new phone!
Hi - You can download the manual by clicking the link underlined in blue below:
H350
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Thank you very much for the above link, just what I was looking for as I lost my manual,
Thank you JR, Bray Co Wicklow , Ireland
need passcode
given as gift, no manual, need total instruction.
i cant get my headset to link to my Gzone casio
I lost my manual and now my phone wont conect to it. what am i doing wrong
Followed these instructions, finally recognized H350 device but unable to connect. I put in the passkey 0000, which may have been a mistake, I don't know-
need instructions to locate phone signal
same problem
Can't get bluetooth to connect to a voice command or pick up without using cell phone
Hi, I've misplaced the manual for the H350 AND NEED TO PAIR IT TO A MOTOROLA PEBL
when i try to pair my device it asks for a pass key and then says that it did not pair
it will not connect to my phone
i can not find the prsskey on thr h350
I have a Motorola h350 and I can't get it to pair with phone
need pass code for motorola h350
I had to buy a new phone. I have a Nokia AT&T Go phone. I lost my Motorola phone. I have a Motorola H350 Bluetooth. How do I pair the bluetooth to my new phone?
i need the passcode for my bluetooth.
Need pairing code for motorola H300
How do I pair my Treo 650 to the Motorola H350 blue tooth head set. My treo sits waiting for H350 to verify password. It never comes back.
Need a manual
missing instruction book to motorola h350 handsfree set. need pass code please
I LOST MY PAPER WORK AND CAN'T PUT IN MY PIN # TO BE ABLE TO USE EAR PIECE IT'S A #H350
The address above is invalid
lost passkey for my bluetooth h350
my son gave me has ear piece its a moto h350 from what i can tell by pictures on internet i have no idea hoe to hook it up???? help
how to pair motorola h350 bluetooth headset with motorola razr2?
Need manual to get PIN to set-up on new cell phone.
lost manual
Need to download to my phone and according to website of Motoral my phone is compatible but it will not recognize it when I try to download it.
I lost my manual. Thay need to make the book bigger so you can find itÂ
I lost the instructions for my H300 motorola headset. I have not begun the 'setup'.
Help!
i lost my maual h300
I need the user manual for Motorola Bluetooth H350.
passcode does not work. need to reset bluetooth. how do i change the code.
Maxey's Mom
have a bluetooth 350 and i forget the pin number. how do i change or delete the old number in there. i purchased a new bluetooth and am giving away my old one.
please advise.
I lost my Manual for my Motorola H350 bluetooth Headset and I am trying to pair it to my new cell phone and it is asking me for a Passcode?
How do I get another one?
I lost my user manual. Then I changed to a new phone and I can't remember how to sink the phone and headset together.
Ive lost my manual for my motorola h300 and I just want to pair it with my lg vx9900
I lost my manual for the motorola H350 and i need the pin number! Can anyone help me?
lost my manual for setting my bluetooth to my phone
dont know the pass key
i lost my manuel and i cant get it to connect to my phone i need to know the code
Had the same issue. I got the info here. Take a look.
http://www.motorola.com/consumer/v/index...
what is the pin?
don't have the manual to get the passcode
need the pass key to set up bluetooth to new phone
trying to install motorla h350 to cricket phone
I am having trouble getting the volume up high enough to hear. Also, does the H350 take a battery?
Lost my manual, new phone, need passcode to activate and I don't remember
i not know the passkey to my bluetooth and i'm trying 2 used iton my new phone
i am trying to change the ring type on my blue tooth headset..does anyone know how to change that
i lost my paper n i cant get the pass key for it
yyjjk
lost instrution manual nned to know how to program
NEED PASSKEY CODE
i canot get the passcode to pair my H350 to nokia 3500
I have the same issue!
Anne, Georgia
[email protected]
I need a pass key for a motorola h300
my boss just gave me his bluetooth h350. he only had it for a week and upgraded to a visor type of bluetooth. he misplaced (rather tossed out!) the manual leaving me to fumble around trying to learn how to hook it up and what the buttons are for. Any help please?
yes I have the same problem but no solution yet
we have lost the hand book and we need the pass code we thought it was oooo but that is not it hope you can help thanks dawn
