Question about Whirlpool Refrigerators
Whirlpool refrigerator model ed25lfxgw00 the edge between the freezer and the fridge is hot
philbran
  • 242 Answers
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Posted on Dec 30, 2008
peyton32034
  • 410 Answers
SOURCE: Kenmore 5126101 middle separator b/t fridge/freezer extremely hot
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Posted on Mar 11, 2009
  • 7 Answers
SOURCE: water is dripping into refrigerator
If it's the same as our GE fridge, there's a tube in the back of the fridge on the outside with an S shaped curve in it that may be plugged up with dust and/or dirt. Clean it out to let the water get through.
Hope this helps.
Johnnyczar
Posted on Mar 20, 2009
  • 18 Answers
SOURCE: Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
Posted on May 29, 2009
  • 103 Answers
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
Posted on May 31, 2009
Front edge of fridge cabinet gets exceedingly hot...too hot to touch!
condensor coil is clogged up, or condensor fan is not running.
Dec 04, 2012 | Refrigerators
Refrigerator is not cold on top, but still cold on bottom.
Sounds as if you have a bad evep. Fan motor. It souldnt by over $40.00. And if the unit still look and works good other than this problem. It's located behind the inside back freezer panel. Diffaculty level in my opinion is a 5 out of a scale of 1 to 10. 10
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Panel between fridge and freezer very hot and no sound at all
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Side by side refrigerator by whirlpool
try vaccumming under your frig coils, and pull away from the wall and clean under there too. i would check to see if the fan behind the unit is spinnig( its suppused to cool the compressor) if its not youll need to replace that.a pretty common problem easily fixed
Oct 25, 2008 | Whirlpool Refrigerators
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
23 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
