Question about Hampton Bay 24002 Ceiling Fan
What is the Dip switch code for Hampton bay uc7083t remote?
Buffalo12980
  • 625 Answers
SOURCE: I need the default code for a hampton bay fan
I checked the hampton bay site and unfortunately whatever dip switch setting on the fan is, the remote needs to be matched to it. better get out the ladder!
Posted on Sep 12, 2007
  • 75 Answers
SOURCE: Hampton Bay Windward II dip switches
The CODE SWITCH RECEIVER should be located in the CANOPY (the bracket hanger). !!WARNING!! YOU ARE ENTERING A HIGH VOLTAGE ELECTRICAL ZONE!!
It will be tucked in among the electrical wiring and inside the hanger bracket.
Simply pull it out and you will see the CODE SWITCHES. There are 16 CODE combinations that can be used. Both the REMOTE and the RECEIVER MUST be set with the SAME CODE.
Good luck. :)
Posted on Apr 26, 2009
  • 10865 Answers
SOURCE: i bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Posted on Jun 20, 2009
SOURCE: HOW DO make the HAMPTON BAY UC7083T CEILING FAN go
you need a hamton bay remote with a reverse button on it. make sure dip switches are same as other remote.
Posted on Aug 05, 2009
SOURCE: The house I bought has a Hampton Bay Ceiling fan
Lift up the upside down cup that sits above the motor. There is a black switch there. I almost lost my mind trying to find the darn thing!
Posted on Oct 31, 2010
My Hampton Bay UC7083T stopped working after having to reset the breaker it is connected to. The remote battery was changed and the dip switches double checked. I cannot turn it on using the wall switch...
Try putting a different frequency in the remote transmitter & receiver. If that doesn't work, you probably need a new receiver. You have a low-end store brand fan made from low-end parts. Remember, you get what you pay for.
Aug 19, 2014 | Dryers
My Hampton Bay UC7083T stopped working after having to reset the breaker it is connected to. How do I fix it?
Make sure the wall switch is in the on position for the remote to work correctly.
Hampton bay uc7078T remote with uc7083T receiver ?
read your instruction manual download from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 29, 2012 | Universal Remote Control Hampton Bay...
Changed batteries in remote fan still doesnt work hampton bay model uc7083t
If you're gettig a red light whenever you press a button on the handle remote, That means the hand held is working. There are also batteries in the receiver , inside the fan's cowling. They need to be changed too. Also, be sure the wall switch is ON. The remote has no control, if the wall switch is OFF.
Hope this helps and thanks for choosing FixYa.
Jul 28, 2011 | Hampton Bay Heating & Cooling
Cannot set remote code for fan/light(dip switch)
The remote dip switch setting must match the fan receiver dip switches. Set them both to 2 on
Jul 04, 2009 | Hampton Bay 52 In. White Redington...
I bought a hampton bay ceiling fan model uc7083t but i didn't
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Need code for remote to ceiling fan
There is no set code from the factory; usually all the dip switches are in the same direction. In order to find the code, you will have to take the fan down, pull the remote out far enough to observe the dip switches, and then set them the same way on the remote.
May 19, 2009 | Hampton Bay 13087 70450 Carousel II...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Sep 11, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay 24002 Ceiling Fan Logo
60 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
