Question about Kenmore 44832 Front Load Washer
No spin, 12 min left, can't unlock the door
After one cycle, i saw the cloth still wet, so add on more min. for spin (12min.) but the machine did not work, i tried to unlock the door, but failed. unplug the power for overnight, still the same. anybody knows what's wrong with it?
thanks.
  • 15,935 Answers
Likely the ECU has been damaged with a voltage spike. Check/replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
We have a Bosch Nexxt 100 Series Washer. The door lock is stuck and will not unlock. We have a load of clothes in the washer but are unable to get the door to unlock. I have tried unplugging the unit,...
Getting the door open is the easy part. Finding out why it won't open might take a little doing -- though replacing the door latch is also easy. To get the door open, Take an awl or something pointy and place it in the hole on the small round cover in the lower left front of the machine. Now use this to turn the cover, unscrewing it from the machine. Once the cover is off, you should see a plastic rod hanging down. Pull this rod and it will unlock the door. You can now remove your wet clothes from the machine and investigate the cause of the problem.
Jan 31, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing machine 11 years old is jumping on the wash cycles. EG instead of taking 25 mins its taking 10 mins to complete -clothes coming out wet unless manually turn to spin again
It is possible that the program is not running to the designed settings and so the program seems to skip the cycle.
The clothes come out wet because the spin cycle is not activated in the set program. Hence the program controller needs a check.
Jan 17, 2011 | Hoover Washing Machines
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Doesnt seem to be cleaning good. should i not be putting so many clothes in it? should I use more soap? I feel like the clothes barely get wet!
These washers use very little water. (about 2 inches in the bottom of the wash tub) The actual amount used will vary based on the volume of clothes and the type. (snythetic clothes do not absorb much water, but put in a load of cotton towels, for example, and the clothes absorb the water, causing the water level to drop, and the machine will add more water to return the level to the set point, which usually takes a several short fills, over a couple minutes)
To see that the clothes are indeed wet, just pause the machine a few minutes into the cycle. The door will unlock, and you can feel how wet they are. When the cycle completes, these machines spin so much faster (about twice as fast as most top loading machines) that the clothes feel very dry. (thus reduced drying time, and additional energy savings) Because of the lower water usage (about 12 gallons vs. about 45 for a top loader) make sure you only use 1 to 2 (max) tablespoons of HE detergent per cycle, and only 1 teaspoon of fabric softner if you use it. (don't use fabric softner on towels) Using too much addatives will cause odor issues, and possible performance issues.
Sep 03, 2009 | LG WM-1832C Front Load Washer
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore 44832 Front Load Washer Logo
109 people viewed this question
Sal De
fordexpert
Robert Rankin
