Question about Polaris Pool & Spa
Polaris 380 Back up Valve- how often do these fail, on average?
    Top Expert:
  • Polaris Master
  • 8,694 Answers
If it keeps on backing up bad it should run forwards about 190 sec then kick in then out
Posted on Apr 23, 2016
  • 128 Answers
SOURCE: having problem with polaris 380 not moving. just
If the wheels are spinning independently you have broken drive belts. The hose swivels are leaking also which could lower the pressure to the head.
Posted on Aug 23, 2009
  • 990 Answers
SOURCE: My polaris 380 wheels won't turn. the belt is
If the wheels don't turn there may be sand in the notches on the wheels, the notches may be worn off, if their is sand or dirt in the paddel wheel jet that will keep the unit from turning and again no wheel movement. All of these problems they can check in your local pool store. Stores will generely check your unit out and fix what is needed for just the price of parts to fix it when you bring it into the store.
If you have no water flow to the unit this will also stop things from working so be sure to check your finger screen before you do anything.
Posted on Aug 25, 2009
  • 106 Answers
SOURCE: How long should the hose be on a Polaris 380 from
One hose length longer than the longest run
Posted on Jan 14, 2010
  • 990 Answers
SOURCE: where in the feed hose do you put the backup valve
About 18" to 3' up the hose from the head.
Posted on Oct 10, 2010
jharwell668
  • 640 Answers
SOURCE: which pressure should i use on uwf polaris assembly 380
It might not be your booster pump. First, check the filter screen and clean if necessary. Often, this is the only problem when these pool cleaners are having problems. Clean the skimmer, pump, and filter also. You will also want to check all connections and hoses to make sure that you don't have a leak.
Posted on Feb 02, 2011
Why on a polaris 380 would water pour out of pressure relief valve and not make it to vacuum
check inline filter or check to see if hose is collapled sometimes the bend where they go into the polaris
Jul 12, 2014 | Polaris 380 In Ground Pool Cleaner
Polaris 380 wheels won't back up
open up unit check hoses on inside if they are off put on and zip tie
Jul 21, 2012 | Polaris 380 In Ground Pool Cleaner
I have a polaris 380 which has stopped working and the pressure relief valve is opening. The inline filter appears to be clean, but I am thinking that there must be an obstruction in the polaris nozz
pressure relief valve on sidewall check oring make sure fitting has both tangs if missing replace if ok see if inside Polaris there is a obstruction
Jul 15, 2012 | Polaris 380 In Ground Pool Cleaner
Have had my current Polaris 380 for around 6 years. Nothing has changed...but suddenly the cast to my backup valve split 3/4ths of the way around above the threads. Replaced with backup valve from...
It is likely a coincidence but you may have a restriction of the water downstream from the device. This would cause a higher pressure and might therefore add to the stress on the backup device. Regardless of the cause you still need to new backup valve or a new part to replace the part that split. They are not hard to replace if you can get it apart.
If you have trouble getting it apart you can bring it down to Leslies Pool Supplies and they can put it back in order for just the price of parts.
I hope this helps.
Sep 04, 2011 | Polaris 380 In Ground Pool Cleaner
I think it is a coincidence. On the other hand, there could be a restriction downstream causing the pressure to be too high. I would check for this but either way you will need to buy a new one. I hope this helps.
Where in the feed hose do you put the backup valve for a 380 polaris pool cleaner
Exactly: No more than 3' from the head.
And that first section of hose is the "Soft" Clear style. The Back up Valve will be installed on it... And that hose should be no longer than the deepest part of the pool.
See pic, back up valve inside the square outline...
Oct 10, 2010 | Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL...
Having problem with polaris 380 not moving. just replaced back-up valve and having a different problem. there are three small devise on hose that are spraying water.
Jul 08, 2009 | Polaris 380 In Ground Pool Cleaner
Pool & Spa Logo
43 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
