Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Fault Code AL03 in an FDW80 dishwasher
Does anyone know what fault code AL03 stands for please?
  • 4 Answers
Al03 stands for problems with the drainage either ur pump is blocked or has just stopped working so not enough pressure to drain out water during cycle
Posted on Jul 15, 2009
AL03, DOES NOT DRAIN AT THE END OF CYCLE, DRAINS AT THE BEGINNING
AL03 - HEATING TIME-OUT
The maximum heating time for the water is 45 minutes; if the correct temperature is not reached within this time, an alarm condition is generated.
Possible causes:
  • Heating element broken
  • Safety thermostat open
  • Wiring interrupted / disconnected
  • NTC sensor faulty / incorrectly positioned / poor thermal contact
Dado
Jun 01, 2014 | AEG 18 in. Favorit 64800 Free-standing...
Would like to know what AL 03 means on a hotpoint ultima dishwasher
It's a AL03 fault code usually a blocked waste pump, you have to go in and remove it and clear the pump and that also meanes taking the pump apart to get all the junk out of it to fix it so it can flow again. it has a impeller on the inside that you will have to pull out be easy with it and have plenty of rags it going to be some nasty black stuff in there.
Nov 16, 2012 | Dishwashers
Error code al03
AL03 indicates a time out on drain fault. Either there is a restriction or blockage on the drain side of the appliance or on the pressure side.If the machine empties ok you need to locate the pressure switch, remove the thin tube and blow back into the sump to try and clear the restriction. If the machine isn't emptying or empties slowly you need to clear the restriction/blockage in the drain hose, pump or sump.
Apr 03, 2010 | Hotpoint Dishwashers
Ariston Dishwasher LD87, error code AL03
for code al03 ,today i resolve the problem it was a pomp like everywhere in sites riding. we open a popm and there have a black lastic and it was inside of the pipe ,so we take it litl bit out and dishwasher work perfect !! it is easy ! dont be afraid to fix it alone .Just be carefull with a lot of water will come out from the pipes. and sore has to be away from electicity)good luck !
Apr 11, 2009 | Ariston Technologies Dishwashers
Ariston Dishwacher error message
I found a very good page for this problem on the internet - http://www.almesberger.net/ld87/al03.html -
After reading that page, I knew exactly what to do. In my case, something had stopped the pump from working, So I could solve the problem without removing the pump.
Mar 21, 2009 | Ariston Technologies Dishwashers
Error code AL03 on fdw 80 dishwasher
Hi yes i did post a problem on the " let our experts fix your problem for free " section, so how long is it going to take as the machine is still not working ? please advise asap
Jan 07, 2009 | Hotpoint Dishwashers
60cm Ultima DWF70 Free Standing
Hotpoint code A03 is a short circuit on the temperature thermistor.
This will need replacing, or there is a fault with the supply wires leading to it.
This should be replaced.
Do you need instructions or the number of an engineer?
If you do, please contact again, otherwise please rate as Fixya! if this has resolved your problem.
Thank you.
Jun 15, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Whirlpool ADP5966 fault code F8
just choose another prog setting and hold the start button in for a few seconds.
Nov 16, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
729 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
