Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow eseries water coming out from the back
When I start to vacuum, water is spewing out from the back Hepa filter.
    Habit-Forming:
  • Rainbow Expert
  • 119 Answers
<p>Please check your <a rel='nofollow' href="http://www.rainvac.com/separator-e">Sepatator</a> to see if it is damaged or missing. If a fin is broken out of the sepatator, this will allow water to be pulled up through the motor and spit out the exhaust.</p>
<p>RainVac </p>
<p><a rel='nofollow' href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Posted on Jun 14, 2013
SOURCE: loud rainbow and water leaking
If pieces are missing or broken I would try and replace the piece. You can usually get these items cheap on Ebay.
Posted on May 03, 2008
SOURCE: Dust blown out of Rainbow SE Performance vacuum
Your separator needs to be cleaned
Posted on Sep 18, 2008
RockyNR1
  • 324 Answers
SOURCE: water leaking from out of the heppa filter
Reasons for that to happen:
a) You have tilted the vac while vacuuming
b) Used the Rainbow without separator (basket like thing on the bottom of the motor)
c) Overfilled the rainbow tank with water (may have happened when shampooing with AquaMate)
Clean and install back the separator, remove HEPA, Set the Rainbow on empty water pan (with HEPA removed) turn it on for a while so everything will dry. Install new HEPA.
You will have to get a new HEPA filter (you can find them HERE)
Good Luck,
Rocky
Posted on Mar 21, 2009
RockyNR1
  • 324 Answers
SOURCE: Rainbow vacuum-water not spinning
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
  • 41 Answers
SOURCE: red light flashing on rainbow
The red flashing light is normal, as long as it does not give an error code, and is a steady flashing, when it is running.
Thank you,
Ralph
Posted on Jan 12, 2011
My Hoover Elite Rewind just lost power while vacuuming and wont power back on?
Hi! It appears your thermal protector sensor has kicked in and caused your cleaner to power off. This is usually due to a clog or a filter that needs to be cleaned or replaced. Try these steps to get your vacuum back up & running!
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Squeeze out the filter and allow 24 hours to air dry.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Your vacuum should turn back on after it cools off, this can take up to an hour. Hope this helps!
Oct 07, 2014 | Hoover Vacuums
My Hoover Elite Rewind just lost power while vacuuming and won&#39;t power back on?
Rainbow filter spraying water just changed filter?
If your Separator is broken, then this will allow water to go up through the motor and out the exhaust. The HEPA Filter Neutralizer 2nd Edition for eSERIES is at the end of the air bath of exhaust so this will be soaked with water. If that does not fix, call us with your Rainbow in front of you for some troubleshooting... Contact Us
RainVa
Aug 06, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Why water comes out when I run my rainbow
Make sure the water basin is not damaged and the separator is on correctly. If the model you have has a hepa filter check it for damage.
Jun 01, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum won't turn on
Be sure to that the latches are connected to the water pan. The eSERIES and up will not turn on without the water pan latched. If that is not the issue, please call us and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Oct 17, 2012 | Rainbow E series Canister Wet/Dry Vacuum
What would happen if I would take out both hepa filters from my rainbow e-series? I do need extra super filtering - previous versions didn't have it and it was ok... Hepa filters are not so expensive...
It won't hurt anything if you don't have a problem with the tiny particles that will be blown into the air. The Hepa filters trap small particles that can be unhealthy to breath. Most of these particles consist of human skin and hair, pet dander, dust mites, etc.. Many people are not bothered by these tiny particles. Others, like asthmatics, can have serious complications from them and the Hepa filters really help.
Nov 24, 2011 | Rainbow E series Canister Wet/Dry Vacuum
If you dopn't change the hepa filter will motor burn up or explode
No. The HEPA filter is simply to collect fine dust and allergens that make it past the water. Hmm. If it gets full/clogged and isn't changed, then the motor is more likely to burn up from overheating. It's more likely it will shut off if the filter gets full. It will not explode.
Dec 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Hepa filter
you generally dont clean hepa filters .. you replace them .. temporarily you can tap them on the driveway to loosen up the big particles .. but the filter normally is replaced ... there are some filters that are washable in hot soapy water .. but hepa filters are normally not ..
Jun 06, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Rainbow E series Canister Wet/Dry Vacuum Logo
283 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
