Question about Toshiba Satellite L750 Notebook
BIOS passwords from time to time. AMI Backdoor BIOS Passwords Reported AMI backdoor toshiba
kornho
  • 781 Answers
SOURCE: Need to reset phoenix bios
have yout tried this application..
http://www.cgsecurity.org/wiki/CmosPwd
I've heard before about the toshiba paralell loopback (it's also mentioned on the website above) as a way to unlock your bios you may want to try that aswell.
post back if it worked.. would be good to know if it did.
I remember also reading about the possibility of flashing your bios (you're going to need a floppy drive unit) to at least unlock your hard drive and get your data out, you may still not be able to hack into the bios again.
Posted on Oct 01, 2008
  • 987 Answers
SOURCE: passwords
you have to remove the CMOS battery and re insert again..
Posted on Jul 07, 2009
parrotheadpc
  • 2600 Answers
SOURCE: bios backdoor for toshiba laptop
System (BIOS) Password Reset
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
Posted on Oct 07, 2009
  • 74 Answers
SOURCE: Is there a backdoor bios
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Nov 05, 2009
SOURCE: toshiba notebook Satellite A215-S6804 Bios
Obviously both of this **** haven't open a notebook before. Even if you take out the notebooks battery (not there in your picture guru/Apprentice) will not solve your problem. did that done THAT with several TOSHIBA SYSTEMS!!! only way is to buy a bios chip!
Posted on Jun 06, 2010
Alert! system protection failure password:.... toshiba satelite pro
Using a Backdoor BIOS Password Some BIOS manufacturers implement a backdoor password. The backdoor password is a BIOS password that works, no matter what the user sets the BIOS password to. These passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.
AMI Backdoor BIOS Passwords Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Backdoor BIOS Passwords from Other Manufacturers Reported BIOS backdoor passwords for other manufacturers include:
Manufacturer BIOS Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX SOYO SY_MB TMC BIGO Toshiba Toshiba Remember that what you see listed may not be the actual backdoor BIOS password, this BIOS password may simply have the same checksum as the real backdoor BIOS password. For Award BIOS, this checksum is stored at F000:EC60.
Her is a list of back door bios password resettes
Jun 20, 2011 | Toshiba Tecra A8-EZ8311 Notebook
Need to rmove bios password in hp pavilion dv6000 laptop
Nov 22, 2010 | HP Pavilion dv6000z Notebook
HOW DO I RESET THE BIOS PASS WORD ON A TOSHIBA LAPTOP L355
Hi if you want reset bios password ( asume you forget it) You need reset bios find reset CMOS jumper or take out battery for few sec. All settings in BIOS will be reset. Let me know if you need more help
Aug 25, 2010 | Toshiba Satellite L355-S7811 Notebook
Sir, I'm very happy to read from you and to know how far you are doing in computer. I'm having problems with my Toshiba Laptop dynabook satellite 1860 . I have being using the my compuetr with...
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
SOYO SY_MB
TMC BIGO
Toshiba Toshiba
Or
Resetting a Toshiba BIOS Password
Download (Keydisk) http://www.cgsecurity.org/keydisk.exe will reset the BIOS password on Toshiba laptops.
Can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk. Format the disk using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
Then put the floppy into your machine and boot it up, you'll be asked for a password, just press Enter. Then when you're asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
Aug 24, 2010 | Computers & Internet
Toshiba Satalite M35 x, trying to clear bios password, i never set it! Plus the keys are locked, password field will not accept anything
I copied this info from a website since it needs a very particular solution. The only time I had to use it, it worked.
Go to setup (if it lets you) and check the BIOS brand and version.
(If you cant do anything due to the password, then you need some hardware to do that). I hope this helps
Resetting the BIOS Password using Software Every system must store the BIOS password information somewhere. If you are able to access the machine after it has been booted successfully, you may be able to view the BIOS password. You must know the memory address where the BIOS password is stored, and the format in which the BIOS password is stored. Or, you must have a program that knows these things.
You can write your own program to read the BIOS password from the CMOS memory on a PC by writing the address of the byte of CMOS memory that you wish to read in port 0x370, and then reading the contents of port 0x371.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
  • ACER/IBM BIOS
  • AMI BIOS
  • AMI WinBIOS 2.5
  • Award 4.5x/4.6x/6.0
  • Compaq (1992)
  • Compaq (New version)
  • IBM (PS/2, Activa, Thinkpad)
  • Packard Bell
  • Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
  • Phoenix 4 release 6 (User)
  • Gateway Solo - Phoenix 4.0 release 6
  • Toshiba
  • Zenith AMI
Apr 26, 2010 | Toshiba Satellite M35X-S161 Notebook
Tecra , laptop bios password needs to be reset.
mera laptop
think pad r40e
bios pass word
my bhool gaya
pls mere ku help karo
Feb 17, 2010 | Toshiba Computers & Internet
Cannot boot laptop because of bios password
Easiest way to wipe clean the Bios password is as follows:
  • Perform a power drain by removing laptop battery pack and/or docking station power supply and hold power button down for 10 seconds
  • Locate the CMOS battery (usually under the smallest panel on the bottom of the laptop)
  • Remove CMOS battery for 20 minutes (20 is arbitrary can wait longer if you wish)
  • Replace CMOS battery and panel
  • Replace battery pack and/or replace to docking station
  • Power up
The Bios password should now be removed and you should be able to boot with no issues. Thank you for using Fixya and please remember to return to rate this answer.
Greg
Nov 17, 2009 | Dell XPS M1330 Notebook
Laptop evon610c with foxconn motherboard i cannot
Try one of the following "Backdoor" passwords
Id guess that your system has a phoenix bios , judging from the bios upgrades available from HP
If you found this helpful , pleaese rate my solution below
Kind Regards
1234s282
Jul 03, 2009 | Compaq Computers & Internet
HARDDRIVE LIGHT DONOT COME ON AND NOW IT ASKING ME FOR A PASSWORD AND I ENTER THE ONLY ONE I EVER USE CAN YOU PLEASE HELP ME? I HAVE NOT ABUSE MY COMPTURE
Aug 13, 2008 | Toshiba Satellite A135-S2266 Notebook
Reset bios password
Aug 10, 2008 | Intel D865GLCLK Motherboard
Toshiba Satellite L750 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
