Question about Epson WorkForce 630 Inkjet Multifunction Printer
Epson workforce 630 won't send fax error a40
Fax function was working, now getting a40 error. Sends first page but second page does not go through. Looked up a40 error says I need to clear fax memory, but can't find instructions on how to do this.
5 Suggested Answers
ljiohy
  • 31 Answers
SOURCE: Need to Fax from my Computer using an Epson Workforce 600
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a17
Posted on May 22, 2009
GetFaxing
  • 143 Answers
SOURCE: how to send a fax
Assuming you want to use WinFax with your scanner...
in Program Setup, go to Scanners option.
Select your scanner from the list.
You should have "Scan and File" and "Scan and Send" options in WinFax. If you don't, the scanner was not detected.
Troubleshooting WInFax at http://www.getfaxing.com
Posted on May 29, 2009
graysand
  • 558 Answers
SOURCE: I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
Posted on Sep 21, 2009
cns assoc
  • 677 Answers
SOURCE: epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Posted on Feb 12, 2010
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Epson 630 workforce won't fax to some numbers.
followed edger allans remedy and now faxes that where not answering before now are. i think mostly because i had it set to, 1 ring to answer and i changed to 6. thanks.
Feb 07, 2012 | Epson WorkForce 600 All-In-One InkJet...
I have an HP L7780. We are having an issue receiving faxing. The pages are often only 1/4 complete. There is no reported error. It doesn't happen all the time.
Send a fax on this number
1-888 HP FAX ME (1-888-473-2963)
and see whether you receive a fax from hp or not whenever HP receives a fax from any number it sends back a fax to prove the functionality you can say.
the reason behind reviving the 1/4th fax can be fault at sender's end
Apr 21, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I have an Epson Workforce 610. It used to send faxes just fine with only minimal errors. Now, I only get error 5303 for the last two months. I am using it wirelessly from my computer, and it prints...
Try this : Look for Setup on your printer and press OK button. Go to Fax Settings, press OK, then go to Communication and press OK. Turn off ECM and V.34. Try re-sending your faxes.
Dec 10, 2010 | Epson WorkForce 600 All-In-One InkJet...
My epson fax machine is hooked to magic jack and every time I try to send a fax, I get: communication error 0404
Can I fax using Magic Jack? This is a popular question. They do not support faxes, but the answer is yes. You may need to do some tweaking. However, not much tweaking. First, turn off error correction on your fax machine or program. Then, set the fax machine or program to use the slowest speed available. The slowest speed will ensure a fax goes through. You may increase later to find the highest speed at which a fax can be received.
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson fax hooked to magic jack communication error
Good Luck
Good luck
Sep 21, 2009 | Epson WorkForce 600 All-In-One InkJet...
Epson WorkForce 630 Inkjet Multifunction Printer Logo
75 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
