Umc tv stuck in standby
Will not switch from stanby
  • 41 Answers
SOURCE: tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Posted on Mar 30, 2009
roety
  • 585 Answers
SOURCE: logic lcd tv.switch it on ,goes straight back on standby
Hi my name is Roety,
I can help you with your issue ,
May have bad capacitors on the power supply other than that its a guesswork game 2 main boards and a screen
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Jan 29, 2010
toolkits
  • 1099 Answers
SOURCE: tv is automatically switching to stanby mode after a few seconds
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helpout......
Posted on Aug 03, 2010
Testimonial: "your a star thank you"
  • 4336 Answers
SOURCE: When i switch my tv
You need a live input source to the port that the TV is set to, or turn on the tv and switch input to a live input source, anything else and the tv shifts to standby.
Posted on Oct 13, 2010
  • 1536 Answers
SOURCE: my tv is stuck in
In my house, I'd remove the back, drag my oscilloscope over and check the power supply for failed capacitors. That is, if I had already tried pulling the plug, waiting half a minute, then plugging it in again to reset a controller chip possibly confused by a power glitch.
I never heard of anybody making a TV without at least volume, channel or source selection buttons. I have seen sets with the buttons hidden behind the bezel on the bottom or side. What is the model number of your set?
Posted on Oct 27, 2010
My sony bravia LED flat tv goes on and standby then on and then stanby again..and afterwards stucks on standby at all.Is the system controller has failure or its power supply?
Before go, the standby/power LED will blink to a certain times, and these blinks are called blinking codes, and are fault indications. From the number of these blinks occur at one time switch ON, you can get an idea about the fault circuit stage inside the TV. If you wish to get more details about these blinking codes, check this link. if you're sound in electronics, you may get it repaired by yourself.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 03, 2013 | RCA Televison & Video
My UMC tv x216/17c-gb-ftcd-uk does not turn on with power applied. How can I test to find the problem
Hi boys,
Hope you are still here. :)
My tv UMC x216/17b gb-ftcd-uk 21.6" doesn't turn on anymore. No LED light but consecutive clicks on DVD area.
The power supply is working (12V), I unplugged the backlight screen board and the DVD unit but still not working.
So I decided to replace the main AV board.
I found on eBay the board with the same code B.LT712C 8373 but for UMC 23" or other makers with different screen size.
Do you think this board will gonna fit on my UMC 21.6" as long as is the same part code ?
Thanks,
G.
Aug 20, 2012 | Televison & Video
When i switch my tv on it turn's itself to standby, i can switch it back on again but it just keep's switching itself to stanby after a couple of minutes.
Oct 13, 2010 | Televison & Video
TV will not switch out of standby
Unplug,replug the tv an hour later,let the tv reset itself,might work again.
Apr 26, 2010 | Philips Magnavox 27MS343S 27" TV
Tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
I have a 19"umc LCD tv,that is in protection mode,how can i fix this problem?
my 19" lcd tv umc model no s19-2ng wont turn on the standby button is flashing on and off please help
Nov 05, 2009 | Televison & Video
Bush lcd 37 inch tv keeps going to stanby
my bush lcd tv keeps staying in standby mode and wont go on if it does go on its only for a minute or two....
Help please
Mar 04, 2009 | Televison & Video
Dmtech TV is stuck in stanby mode
The problem IS PROBABLY BEING CAUSED BY A SHORTED POWER REGULATOR (MX084 ) OR AN OPEN FUSEABLE RESISTOR IN THE POPWER SUPPLY...
thank u rate me!!
Feb 12, 2009 | Sony KV-32S42 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
