Question about Epson Office Equipment & Supplies
My Epson Stylus NX430 paper out load paper problem
pineworks
  • 4041 Answers
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
Ajkill
  • 2035 Answers
SOURCE: Always Paper Jam in Epson Stylus CX3500
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Nov 26, 2008
asabur
  • 102 Answers
SOURCE: Epson Photo Stylus R300 paper error
Please replace holder shaft & Roller ******
Sk. Abdus Sabur
Posted on Jan 03, 2010
Testimonial: "many thanks for your reply - looks like is could be expensive (more expensive than replacing the printer?) i'll take it to an epson repair center"
tech-agent
  • 83 Answers
SOURCE: loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper Follow these steps to load paper: step_1.gif Slide the edge guide to the left. ha5280001h.gif step_2.gif Fan a stack of paper, then tap it on a flat surface to even the edges. step_3.gif Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly. ha5280002h.gif ha5280003h.gif mark_no.gifNote: Leave enough space in front of the printer for the paper to be fully ejected. Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures. Make sure the paper stack fits under the fon4_99.gif arrow mark inside the left edge guide.pls vote for me
Posted on Mar 16, 2010
SOURCE: how do i load the
hey you need to move the grey plastic to the left side by gently slide it over to the left side that is the one what is drives the paper ... i just found out when my buddy came over that this thing eats hes paper and since i was the one who had recommended to him i felt like to do something that is how much as far i went in the discovery :D cheers
Posted on Jan 23, 2011
How to change paper from photo to plain on Epson Stylus nx430, the side arrows have disappeared.
You can't change the paper type on the printer itself. You need to go into the document and when you select the printer to use, you will see printer properties. You should be able to change paper type on that screen.
Jan 17, 2018 | Epson Office Equipment & Supplies
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
Installed windows 10 from 7 an my printer cannot print help????
Congratulations - U now have a driver issue and if Epson does post a driver for win 10 you are outta luck!!!!!!!!!!!!!!!
Should not have upgraded and now you need to buy a new printer.
Oct 22, 2015 | Epson Stylus NX430 All-in-One Printer
Paper Jam always comes up every time I turn the printer on. I checked THOROUGHLY, no paper at all!!
If you have ever printed labels using that printer a bit of adhesive may be stuck on the guide roller, use rubbing alcohol to remove it with light rubbing and a cotton ball. Otherwise, with the cost or printers these days, buy another EPSON that uses the same ink cartridges and use your previously opened ones FIRST from your older machine.
Mar 04, 2015 | Epson Stylus NX430 All-in-One Printer
Cant print anymore print counting is almost full. how to reset count
try this
Manual reset methods several EPSON Stylus Color. Actually there are two methods to reset epson printers counter, that is using software resetter such as adjustment program or SSC service utility or using manual by combination pressing button on the printer. If Reset using software resetter you can follow the way of usage the software but sometimes software resetter for the printer is not available. The only way to reset the printer if software resetter not available you can use manual reset.
The Following manual reset for some EPSON Stylus Color Printers:
1. EPSON Stylus Color
Pressing and holding ALT+FONT+LOAD+PAUSE buttons combination
press POWER button
Release all buttons
2. EPSON Stylus Color 300
3. EPSON Stylus Color 400, 600
Pressing and holding LOAD/EJECT and CLEANING buttons
press POWER button and hold it until you will see blinking INK OUT and PAPER OUT leds
Release all buttons
In 2-3 seconds time press LOAD/EJECT and CLEANING buttons again.
4. EPSON Stylus Color 440, 640, 740, 460, 660, 670, 760, 860, 880, 1160
press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
5. EPSON Stylus Color 680
Pressing and holding LOAD/EJECT and CLEANING buttons,
In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
6. EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons
press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
7. EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led
Release all buttons
8. EPSON Stylus Color 800, 850
Pressing and holding LOAD, CLEANING Color and CLEANING Black buttons
In 2-3 seconds time press and release CLEANING Color button, You will see leds blinking.
9. EPSON Stylus Color 900, 980
press POWER button, You will see blinking INK OUT led
Release all buttons
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
10. EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons
turn on printer.
Mar 17, 2011 | Computers & Internet
Inserting A4 paper
maybe this Site helps.
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX100-_E
Here you can find many documentations e.g. for your Epson Stylus SX100
Jun 02, 2009 | Epson Stylus CX6400 All-In-One InkJet...
2,561 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
