Question about Konica Minolta DiMAGE G500 Digital Camera
Can no longer focus when taking close up pictures.
Can no longer focus whe taking close up pictures. The camera no longer has the front plate on the lens. I was wondering if this is something that I could replace and clear up the problem. And do you know where I could get the part needed?
    Genius:
  • 2,985 Answers
This is a repair shop job and they may not be able to get the plate either. Low end camera are essentially throw away when bust
Posted on Jun 09, 2007
My d80 wont take pictures in auto,P,S or A modes. Will click in M mode but no picture. What am I doing wrong? Treied to reset, but still does not work.
The camera will not take a picture in P, S, or A if the camera is in Auto Focus mode - and is unable to focus. Make sure that the Auto / Manual focus switch on the camera body AND the lens are BOTH in an Auto Focus mode. A tip off would be that you do not hear the lens focus motor running while trying to find focus.
If you do hear the focus motor, you may not have sufficient light on the subject for the camera to find a contrast "edge". In this case, the focus motor will hunt from where ever it is all the way in one direction, and then all the way in the other - trying to find focus. You'll need to provide more light or if you have the focus assist lamp (on the front of the camera) enabled - make sure your fingers are not blocking it while 1/2 pressing the shutter.
You can take pictures "all day long" in Manual Focus mode regardless of whether the subject is in focus or not. The lower left corner has a green circle or disc that indicates proper focus. Otherwise, a green triangle shape will be visible close by.
More info on Focus is available here. I hope this helps and good luck! Please rate my reply. Thanks.
Nov 07, 2011 | Nikon D80 Digital Camera with 18-135mm...
I can't get the lens to focus at all on any close up setting manual or auto. I have been trying to take pictures of flowers and insects with it set to close up and I have tried also with it on manual...
The 70-300mm lens won't focus closer than about 5 feet (1.5 meters). If you need to get closer, there are several alternatives. Here are some in descending order of cost (and picture quality).
A special "macro" or "micro" lens. Some lenses are designed to focus closer than others.
Extension tubes. These are tubes that fit between the lens and the camera body. By putting more distance between the camera and the lens, the focus point moves closer to the camera.
Close-up lenses. These are like filters in that they screw onto the front of the lens, but act like a magnifying glass.
Sep 04, 2011 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
I own a Nikon D5000 and am experiencing issues with the 55x200 lens. When trying to take a picture (on auto mode) of an item that is too close, I am hearing a squeaky noise (like the noise made my a VCR...
The 55-200mm lens does not focus closer than 1.1 meters (3.6 feet). If the subject is too close, then the autofocus tries and fails to focus or keeps trying (and squeaking). Either way, you won't be able to take a picture. In manual focus, you can take a picture but it will be out of focus and blurry.
Every lens has a minimum focus distance, closer than which it will not focus. Some lenses focus closer than others. It's a matter of design; making lenses focus closer makes them larger, heavier, and more expensive.
If you want to take close-ups, you have several options. You can buy close-up adapters that fit onto the front of a lens. You can buy a special close-up lens ("macro" or "micro" lens). You can buy extension tubes to fit between the camera and a lens.
Jul 18, 2011 | Cameras
Focus error (can't take pictures) A310 Fujifilm camera Camera shows "Focus Error" and does not take pictures
A couple of quick things come to mind first is you may be way to close to your subject for the camera to focus OR you are trying to take a pictures of a shiny subject, painted wall a mirror or some other subject that lacks contrast
Dec 22, 2010 | Fuji FinePix A310 Digital Camera
Is there a adjustment button somewhere on the camera for taking pictures at close range? When I take a close up shot it is blurry. Let me know if any kind of adjustment can be made. get back to me at...
It's hidden, right there on the front of the unit! On the distant setting (mountain icon) it will focus down to 60cm; on the close-up setting, called "macro" by photographers, (flower icon) it will focus down to 10cm.
Feb 27, 2009 | HP Photosmart E317 Digital Camera
All of the pictures taken are very fuzzy no matter what you do
check to see if a flower appears on the screen. If it does then the camera is set to macro and all your pictures except close up will be fuzzy. To switch macro off, move the ring on the front of the camera till the arrow is pointed straight down. I was having the same problem. Wasted a whole day of vacation pictures. That was what fixed my problem and I hope it fixes yours too,
Feb 17, 2009 | Samsung Digimax A503 Digital Camera
Nikon d40
The G series lenses won't work in AF mode on the newer, entry-level Nikons. They require the DX series.
Jan 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Canon G9 digital camera
There are two stages to the shutter release. The first stage is the focus stage pressed half way down and the second stage is the actual shutter release. Always press the shutter half way to get the camera focused first then press all the way down when the camera is ready to take the shot. Check to see how the settings are with regard to how it focuses (9-point, face recognition, etc). When the camera focuses you should get a green box or multiple green boxes depending on your settings. That tells you the camera is ready to take the picture. Pressing the shutter all the way down at once from the beginning will cause the pause you describe since the camera has to first focus then shoot the picture. Depending on the subject or subjects the camera may take a second or two longer to focus. With good lighting my G9 focuses pretty fast. Hope this helped.
Aug 31, 2008 | Canon PowerShot G9 Digital Camera
Sigma 28-300 3.5-6.3 won't focus
Did it ever work on this camera?
I have seen some Sigma lenses that are auto focus on canon film cameras but then when put on the digital they dont work right. If you have used it on this camera then make sure the lens is clean.sometimes dirt on the front wil make it try focusing on the dirt. Next try focusing in manual focus to make sure the focus is working. Then take the lens off and then put it back on and make sure it clicks into place.
Let me know if none of those things work. also make sure to try focus on something close and somthing far away.
let me know how it works,
Caleb
Jun 26, 2008 | Sigma 24-70mm F3.5-5.6 AF Zoom Lens
Better Focus
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures').
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Konica Minolta DiMAGE G500 Digital Camera Logo
27 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
