Question about Plumbing
How to Replace spray hose on WaterRidge kitchen faucet
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
meBNme
  • 334 Answers
SOURCE: side spray has very low pressure
Disassemble the sprayer and remove the dirt and dibri gathered inside.
Reassemble.
Has the water been turned off to that faucet, or the entire home recently? If yes, it probably loosened sediment in the pipes and its clogging the sprayer.
Posted on Dec 06, 2008
arealplumber
  • 33 Answers
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Posted on Dec 09, 2008
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
SOURCE: Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Posted on Apr 26, 2010
We have UPC kitchen faucet:WaterRidge NSF 61/9. plate is completely rotten,spray does not work. I think we are allegeable for faucet replacement because of life time warranty. sincerely, Yelena.
good luck with your "life" time warranty
contact the manufacturer if they are still in business and make a claim for a replacement or refund.
if it becomes too much of a hassle , junk it and get a n better make
Dec 28, 2016 | Plumbing
How do I replace the sprayhead?
replace the sprayhead Dragon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kitchen Sink Faucets How to Remove the Spray Head From Sink
How to Repair Single Handle Kitchen Faucet With Spray Hose Kitchen Plumbing
Pull Out Kitchen Faucet Sprayhead Replacement
Replacing the Kitchen Sink Spray Nozzle
May 25, 2016 | Plumbing
Wateridge Olivia. Where can I get a manual?
Customer Reviews: Water Ridge Pull Out Kitchen Faucet
www.amazon.com/Water-Ridge.../B00O2AGROM
Amazon.com, Inc.The older Water Ridge faucet had a 6 page manual; it seems the company .... me a new Olivia Pullout Kitchen Faucet by WaterRidge' Dual Function Spray Head ...
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed ...
? 3:21
https://www.youtube.com/watch?v=wsreMTL_whc
Apr 19, 2013 - Uploaded by HillBrosReviews
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed Nickel .... gave me a new Olivia Pullout Kitchen Faucet byWaterRidge' Dual Function Spray ... They sent a hose... with nodirections how to replace the defective one.
Dec 18, 2015 | Plumbing
Waterridge kitchen faucet pull out
Hello, I would recommend replacing the faucet.
Sep 28, 2013 | Plumbing
Do I have to remove the entire Delta kitchen faucet in order to replace the pullout faucet hose? If not, can you give me step by step instructions on how to replace it? Thanks.
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Feb 14, 2011 | Delta Faucet 470-DST Signature Diamond...
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
Oct 04, 2009 | Delta Faucet 470-DST Signature Diamond...
Broken thumb lever to a kitchen faucet side spray
Unless you have a super duper fancy faucet, all spray head for kitchen faucets are standard, and can be picked up at any hardware store, home depot, lowes or plumbing supply.
The easiest method of replacement is to screw off the handle, and leave the old hose intact. On the hose you will find two black washers. one fat and one thin. Take note which one comes off first and replace in that order. Pull back the screw housing and you will see the white plastic tube on the end of the spray hose has a locking ring nestled in a groove. Remove it. Now you can remove the old screw housing and put the new one on. After putting the handle screw housing on the hose, install the lock ring back into the groove., put washers back on in correct order, and screw your new spray head on. Good luck!
Apr 08, 2017 | Plumbing
Delta kitchen faucet mixed spray...diverter problem???
Delta Faucets
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
365 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
