Question about Acer Aspire 3000 Notebook
When i try to remove avg8 from my pc it doesnot.I want a solution.
  • djulies Jan 13, 2009
    I am still unable to rid the computer of the AVG8 antiviras
  • djulies Jan 14, 2009
    I don't know if I'm doing something incorrect but I don't seem to get it
    fixed?
  • 827 Answers
And after you have tried what Joe recommended and you are still unsure, you can download and install nCleaner, do a 'Clean System' and a 'Clean Registry'. This will cleanup any 'orphan dll files' and delete any registry pawprints.
You can also 'Shred Free Space'. This completely wipes any traces of files, which can remain, even after they are deleted from the Recycle Bin.
Hope this is 'music to your ears'.
Chris (ziraffa)
Posted on Jan 11, 2009
  • chris grams
    chris grams Jan 13, 2009
    Try this:
    Click Start button
    Go to Run and type "regedit" (type without quotes)
    a) use Ctrl + F and type AVG8
    or
    a) directly go to HKEY_LOCAL_MACHINE\SOFTWARE key in the registry and you will find AVG folder, remove that.
  • Acer Master
  • 4,338 Answers
You have to download and reinstall it, the first thing it will ask you is "do you want to uninstall the previous version" click yes and let it uninstall. The you have the option whether to reinstall it or not.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
  • JDTec
    JDTec Jan 14, 2009
    Again Solution #1:
    Unfortunately, at this time Grisoft, the maker of AVG, does not have an uninstall utility for AVG. The recommended procedure is a time consuming one. You must download the latest version of AVG from the website, and then run it.
    1) Click on the following link and download AVG to your desktop
    http://free.grisoft.com/doc/5390/us/frt/...
    2) Double-click on the downloaded file to run it
    3) AVG will present you with three options to choose from. Choose the Uninstall option to completely uninstall AVG
    Add/Remove Components - choose if you want to add/remove some components or reinstall the entire AVG program
    Repair installation - this option repairs or reinstalls missing or damaged components of AVG
    Uninstall - this option removes the AVG program from your PC
    4) Once the uninstall has completed, restart your computer. You can then proceed to install another antivirus or install AVG again.
    Solution #2
    When you are working on your computer and installing a new program, the installation suddenly fails. Now you are left with a partly installed program. You try to install the program again, but you are unsuccessful. Or, maybe you have problems trying to remove an old program because the installation files are corrupted.
    Do not worry. Windows Installer CleanUp Utility might be able to help. You can use the utility to remove installation information for programs that were installed by using Windows Installer. Be aware that Windows Installer CleanUp Utility will not remove the actual program from your computer. However, it will remove the installation files so that you can start the installation, upgrade, or uninstall over.
    http://support.microsoft.com/kb/290301
    Good luck, Joe
I am not able to install kaspersky security software into my system, it says you have to delete avg8, i tried everything till now, avg8 is not in my system. how to i install this kaspersky or uninstall...
Kaspersky tells you whether this is because at some point that was installed on the PC AVG8, but is unlikely to be removed either. I recommend you look for the installation of AVG8, install and then uninstall icon from the Add / Remove Programs control panel. This should eliminate all traces that may remain in the system of AVG.
After this reboot the PC and can install Kaspersky without any problem.
May 13, 2009 | Internet Avg AVG Security V8.0 WIN - 2...
I can,t remove avg8 anti virus from my computer
load to safemode and try it , you should be able to do it, let me know wat happen after?
Best Regards
Mar 02, 2009 | Acer Aspire 3000 Notebook
How to uninstal avg 7.5 ?
try to download the avg8 from here and install it. then if you want to uninstall run uninstaller from controlpanel for avg8.
the avg8 should be able to remove avg7
Feb 24, 2009 | Microsoft Windows XP Professional With...
Can't install kaspersky beacause avg8 not uninstalled
u must have not properly uninstalled AVG properly, remove it from registry also. If you cant do it try any uninstaller software to remove avg completely
Dec 19, 2008 | Computers & Internet
Cannot uninstall avg 8 completely
I have had AVG for a long time and it beats any antivirus i have ever had. but if you really want to remove it, use the add/remove programs, or go to the star menu, programs, AVG folder and select the UN-installer. once removed, then try again to install the new one. Make sure to select ( remove Virus Vault ) in the option when un-installing AVG.
If your still getting issues, go into C: and delete any remaing AVG system folders that may be left behind.
Good luck
Dec 01, 2008 | Packard Bell Easy One Silver 2120 Notebook
Problem installing kaspersky
open registry editor and delete the registry values belonging to avg... search using keyword avg etc etc and delete them... usually registry is used to find what all software are present..
Nov 23, 2008 | Acer Aspire 3000 Notebook
Uninstalling AVG8
Goto regedit thro run command and search for AVG keyword and delete all files related to it!!!
Jun 08, 2008 | Computers & Internet
I am trying to uninstall avg8 free and it keeps failing to comply. I believe avg8 free is causing all sorts of problems with my computor. I purchased avg8 yesterday and I am now trying to download it , but...
go to control panel add and remove program click on it then select it.it will remove if he does not work try to install it back and uninstall it back
May 31, 2008 | Computers & Internet
I can't remove AVG8.0 from my computer
Hi
Thanks for the solution for the removal of the offending avg8 problem. I was immediately able to install the kaspersky program, after deleting the remains of the avg8 program,you guys are great, will contact you again if need be .
Best regards Ian
May 25, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
