Question about Baby Lock BL1556
Model b15 on a Denim Pro II how do I put in a bobbin?
The machine seems to be missing the part in which the plastic bobbin is inserted and I can't find a manual or the part. Any suggestions?
2 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Posted on Mar 17, 2009
GC 500/550 not pulling bobbin thread. My wife has used the machine several times without issue, the last time she broke a needle sewing some denim, we found most of the needle but could not find it all,...
some sewing machines can not sew denim good,
here are some suggestions
since a needle was broken & replaced--if the needle has a flat side it goes to the back of the machine
make sure the needle is inserted correctly & pushed up inside of the needle holder & the needle screw tightened correctly
is the correct needle being used for the thread & fabric being sewed?
when sewing denim, a denim needle is needed, I usually purchase mine at walmart, I have 2 necchi sewing machines & the denim needles work just fine on my machines.
if none of the above suggestions help then the machine could be out of time, just because of a broken needle. only a repair shop has the correct tool to fix this problem
Sep 09, 2011 | Singer CG754 Mechanical Sewing Machine
What bobbins fit the singer featherweight 117
The Featherweight II 117 uses the Class 15 bobbin. A 4-pack of the Dritz equivalent of the bobbin is available from Amazon here: http://www.amazon.com/Dritz-Plastic-Class-15-Bobbins/dp/B000Y3D1NG . Singer has a 10-pack of the bobbins here: http://www.singerco.com/accessories/detail/2075/class-15-bobbins-10-pack . You can buy a manual from Singer, as well. (See their Instruction Manual page from the Customer Support Link then enter 117 in the Search box.)
I hope this helps.
Sep 07, 2011 | Singer Featherweight II 117
Needle does not pick up thread from bobbin
Is your needle inserted with the flat side facing the rear of your machine? Are you holding your top thread as you rotate your handwheel toward you to lower the needle? Is your bobbin threaded right, check your manual. It is usually something very simple when this happens.
Sep 09, 2010 | Euro-Pro Denim Sewlution 380 Mechanical...
Where can I get bobbin replacements for my Euro Pro EP 380 Denim Sewlution machine? It only came with one. Online somewhere?
You should be able to pick up bobbins to fit the machine at any fabric store. Just take the one you have with you - make sure it still has thread on it, so it isn't taken for store stock.
If you are looking for a bobbin case, then contact the manufacturer's parts department. The number is listed in the back pages of the machine manual. You can also call in at your local sewing machine repair shop - establish a relationship with the repair person. It will serve you well in the future. Good luck!
Aug 30, 2010 | Euro-Pro Denim Sewlution 380 Mechanical...
Trhreading
http://cgi.ebay.com/Euro-Pro-Deluxe-Denim-Silk-Sewing-Machine-EP-377_W0QQitemZ8271336746QQcategoryZ3118QQcmdZViewItem#ebayphotohosting If so it threads just like my sewing machine.Draw your thread across the top,down into the first slot,then up and thru the second slot,come down,pass it thru the thread guide on the needle,then thread your needle.Most all machines are basic when it comes to threading.HTH
Kathi
May 20, 2009 | Sewing Machines
I lost the bobbin casing
Sew4Less,com has a bobbin case listed for $19.95. Go to www.Sew4Less.com. In the blue box on the home page, fill in the blanks. Step 1: bobbin case. Step 2: Euro-Pro Step 3: 9025 Step 4 click Find Products and you're there!
May 04, 2009 | Euro-Pro 9025 Computerized Sewing Machine
Babylock Denim Pro 1750 Manual
needle keeps working while trying to load bobbin
May 03, 2009 | Baby Lock Sewing Machines
Mar 17, 2009 | Baby Lock Sewing Machines
Need to replace a bobbin cover plate
Here in Australia, the dealer would get it in for you. The 'manufacturer' / distributor usually don't get involved with customers! I'd find a dealer near you and ask!
Oct 08, 2007 | Sewing Machines
Sewing Machines Logo
213 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
