Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
Problems with my 2 KUDS01FLSS1 KitchenAid Superba Dishwashers. Yes I own two of these dishwashers and both are not working...Please help me!
I own 2 model KUDS01FLSS1 KitchenAid Superba Dishwashers. The first unit had the clean light blinking so I read the post below and reset it. I thought everything was fine but half way during the cycle it shuts down and the "Clean" light starts blinking again. The other unit just won't start. The lights are fine meaning the "Clean" light does not blink but even after reseting that unit there is no noise when the "normal" or start or combination of those too buttons are pushed. The lights seem to be working fine on that unit and thinking that could be a door latch issue. Can someone help me here? Thanks
  • 1314 Answers
SOURCE: Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Posted on Jan 01, 2008
  • 1314 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Posted on Feb 12, 2008
  • 25 Answers
SOURCE: Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Posted on Jan 23, 2009
SOURCE: Dishwasher Reset / Diagnostics
Unscrew and remove the kickplate at the very bottom of the dishwasher. The tech sheet with the diagnostic code should be attached to the back of it.  If not, due a websearch and you should be able to find the info on yahoo or google.
Posted on Jan 30, 2009
  • 423 Answers
SOURCE: Heating element circut malfunction In Dishwasher. Wash not workin
Great job walking through the possible causes! Hey, it is time to check the heating element itself. First visually, looking for brakes and then feeling for "bubbles" on the round element rod. Also see if it moves excessivly when you wiggle.
If no problem obvious, after you disconnect the dishwasher from power, use a multimeter to check for resistance (Ohms) If none, look for broken (heavy guage) wires and replace what's broken - probably the element itself.
If the element checks out good, suspect the thermistor then the controller/PCB.
Good Luck! Please report back what you find, OK?
Posted on Apr 11, 2009
MY KITCHENAID DISHWASHER FAILS TO POWER OFF
Programmer fault.......time for repair man or replace machine. I assume out of warranty.
Jul 21, 2014 | KitchenAid 24 in. Built-In Superba Series...
Dirty vent
YES IN ONCE YOU CHANGE THE FILTER BEFOR YOU WASH ANYTHING CLEAN IT WITH BLEACH TO MAKE SURE THE SMELL IS GONE
Jan 18, 2013 | KitchenAid Kitchen Aid Superba Series...
I have a kitchenaide Superba Monterey 21, whisper quiet dishwasher that will not drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 05, 2011 | KitchenAid Dishwashers
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
My KitchenAid Superba won't run, no lights, nothing
turn off the power at the breaker and let it stay off for at least one hour
Dec 17, 2008 | Dishwashers
Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Mar 07, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
143 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
