Question about Fisher Washing Machines
Fisher and paykel model gw708u diagnostic codes washing machine
  • 1294 Answers
SOURCE: service manuals and diagnostic codes with results/reset code
Click on Fisher & Paykel (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line!!
Posted on Sep 21, 2007
SOURCE: fisher and paykel washing machine
i have a fisher & paykel top loader washing machine. At the end of the washing cycle the water does not drain out. What can I do will I need to call for a service please advise
Posted on Nov 23, 2008
http://www.aars.com.au/F&P%20Service%20manual%20517735.pdf
Posted on Feb 06, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
GW708U Fisher and Paykel Washing machine Power Controller board trips earth leakage breaker
Hi your pump may be leaking the earth to trip breaker.
Check or replace the pump.
Feb 04, 2013 | Fisher and Paykel Washing Machines
My fisher and paykel gw708u is intermitantly filling then goes into alarm and stops
Your rotor position sensor could be faulty,
your error code should be on the wash cycle progress lights.
Nov 18, 2012 | Fisher and Paykel Fisher & Paykel Washer
Every wash, the machine on rinse/spin cycle, makes a clicking noise and gets out of balance. I have tried to balance the machine and this has not worked. I need to manually redistribute the washing load a...
Hi Sandra, I'll have a look into this. This machine isn't my usual brand, so I'll have to see what I can find out for you. I'll get back to you by tomorrow :) Joe
Oct 04, 2011 | Fisher and Paykel Fisher & Paykel Washer
Hi I have a GW708U Model. The lights on the display panel come on and then nothing happens when you hit the Start button. Any suggestions welcome.
Hi just read your posting.Just a couple of questions, Do you hear a beep when you push the start button?IF you don't then the problem is your display board.If you hear a beep and it does not start then the problem could be your lid switch.How old is your machine?Please reply with more information and I can help you track this problem and repair it.
Jun 06, 2010 | Fisher and Paykel Fisher & Paykel Washer
Pump blockage on fisher and paykel gw708u top loader washing mach
dont do that the pump is fitted under the sytem there should be a small plastic plate at the front of the machine to get to the pump or go under the unit and its right there un plug the motor pull back the plastic lock gard and turn .the motor should just fall of ..replace as taken off good luck
Apr 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine won't start
Hi there
i'm not sure if the fisher and paykel machines are any different in new zealand compared to where you live, but the only thing i can think of if it isn't displaying a fault code is if this machine is fitted with a reed switch(these make sure the machine stops if the lid is opened during operation) this may be faulty and staying open causing the machine to stop when the lid is closed. Hope this helps.
Jul 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
Power on washcycle won't start and light just blinks
Aug 18, 2008 | Fisher and Paykel Fisher & Paykel Washer
Service manuals and diagnostic codes with results/reset code
Sep 21, 2007 | Fisher Paykel Eco IWL16
Washing Machines Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
