Question about Aurora Electronics AS-650C Cross-cut Shredder
I opened the shredder to get the paper out and now the plastic thing inside I don't know out to put it back
  • JC45 Jan 18, 2009
    How did u get apart? I took out the 6 screws and something is still holding the two halfs together.
    If I can get apart may be able to offer some suggestions on getting working???
    JC
Remove the label underneath the center there is a screw under there.
Posted on Jul 27, 2009
How do I fix the rollers that won't turn when paper is inserted in shredder?
That shredder is as weak as they come - it is probably a broken plastic part inside the mechanism. Recommend you throw it away and get the Amazon Basics shredder, your experience will be much better. Sorry.
Jan 16, 2015 | Royal Office Equipment & Supplies
Paper jam
Does it sound like the motor is spinning? or does it sound like the motor is bound up? I ask because if it sounds like the motor is spinning, then chances are good you stripped a plastic gear somewhere in the drive system that feeds the steel shredder. I just pulled apart one of these and saw that the motor has a steel gear on it. that steel motor gear meets with a plastic gear, and then the plastic gear meets with steel gears attached to, and which spin the shredder. So if you ever bind the shredder with too much paper, the steel motor gear will grind the teeth right off the plastic gear and it won't spin anymore. If your motor sounds like it's bound, then the good news is that the gears aren't stripped. You'll have to take the shredder apart so you can remove the paper causing the problem. Of course unplug it first before opening it up. They are not overly complex but just remember where the screws goes so you put them back in the right holes.
Sep 01, 2014 | Office Equipment & Supplies
How do you take apart a shredder it does not go forward
when my Aurora- AS662C shredder wouldn't go forward I assumed it had paper jammed into the blades -with it unplugged of course ,I removed 5 screws (back does not release) used tweezers to remove the jammed paper. When I initially pried it open- an off wt. plastic bar type thing fell out of it's place (on right side ) I set the plastic bar into it's place(if you look at you'll see how it set's into place, carefully closed the top making sure the bar didn't move and replaced the screws. I then ran papers through it -worked like new ! I almost bought another one and was about to throw it out ,figured I didn't have anything to loose . Best of luck -hope this helps
Feb 24, 2013 | Aurora Electronics AS662C Shredder
Royal 150MX When you put paper in it does not
If the cutting blades do not turn when it is running then you have likely boken a plastic gear inside.
You will have to open it up to see which one...then you can contact Royal at 1-800-524-0799 for parts assistance and pricing.
Dec 30, 2010 | Royal 150MX Cross-Cut Shredder
Tried to feed to much (thickness) through ... I have done this in the past but was able to remove jammed paper by going forward and back until jam was cleared ... this time however it seems the motor just...
This is the most common problem...people put TOO MUCH paper in shredders... the VF880 has plastic gears inside...having done this a number of times you may have broken the gears or stripped the "teeth" off the gears...open it up to see what damage has been done; once you know what is broken you can contact Royal for pricing and parts at 1-800-524-0799.
Dec 11, 2010 | Royal VF880 Shredder
When I put a sheet in to shred, the shredder makes the normal sound but nothing happens. The same thing happens for reverse. This has occured after I had cleared a bad paper jam (there doesn't seem to be...
You dont give make or model???...however it sounds like you may have lost/broken a plastic gear inside..( the normal sound is the motor running??)...open it up to see what has been broken then contact the manufacturer.
This call was logged under "ROYAL" so if it is a Royal shredder you can contact them at 1-800-524-0799 for parts assistance once you know what is broken.
Dec 08, 2010 | Office Equipment & Supplies
Paper shredder does not turn off. I have to open
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
Jul 30, 2009 | World Office Products Papermate PM-1550CD...
Paper shredder
Shredders have a light emitter and detector inside the slot where you put the paper. When the paper is put in, the emitted light is reflected off the paper, detected, and then turns on the shredder by sending a signal to the control board. The emitter/detector often has a plastic cover which over time collects paper dust. The paper dust can reflect the emitted light back onto the detector, causing the shredder to remain on. You may need to remove the top of the shredder and remove the shredding mechanism to get to the light sensor. It's also possible that the components on the control board have changed value, causing the detector sensitivity to increase. This may result in the unit turning itself on in daytime and off at night.
Jan 15, 2009 | Fellowes DM15C Shredder
Not feeding
usually this indicates that the bin has not been properly put in place. On the inside of the waste basket there is a plastic piece that fits up into a slot on the shredder head This is our safety interlock. If plastic tab is bent or broken machine will not run without safety interlock engaged.
Jan 18, 2008 | Fellowes PS60C-2 Shredder
Paper Shredder will not shut off when in auto mode
if you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
Jun 14, 2007 | Royal VF1012mx Shredder
Aurora Electronics AS-650C Cross-cut Shredder Logo
181 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
Jim Keysor
Randy Schumann
Randy Schumann
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
