Question about Schlage B362 619 KA4 Dbl Cyl Deadbolt Per 004 Ea
Deadbolt becomes stuck without a lot of force.
5 year old home. If the thumbturn is turned too far, the lock will become stuck. Have to jolt the lock to get it unstuck. The thumbturn has a little play in it. Face plate lines up. Also, the problem is not due to the ground settling. Tail piece needs greased? If so, with what?
  • 843 Answers
This sounds like the fit between the thumbturn and the bolt is compromised. If you pull out the thumbturn, take a look at the flat metal blade that fits into the rectangular or "8" shaped hole in the deadbolt mechanism. I think this has become bent or misshapped somehow. Or maybe the hole has a rough burr on it. You might be able to flatten the blade with a hammer and anvil or maybe dress up the problem with a file. Good luck.
Posted on Dec 04, 2012
2 Suggested Answers
spencerfield
  • 31 Answers
SOURCE: B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728: Gatehouse deadbolt 2 tears old.moves about 1/2 inc...
Remove, lubricate with a dry silicone or graphite lubricant and reinstall. The mounting bolts may have loosened up, and now it is not perfectly lined up. More likely is some corrossion or wear in the throw mechanism.
Posted on Oct 13, 2010
Our schlage lock with thumbturn on inside and keyed on outside. inside lock position AND outside keyhole are sideways. is this normal??
I've never seen a lock like that was intended to be that way, but have made that mistake when the shaft that goes through the bolt portion of the deadbolt is square and is 90 degrees off in the square hole it goes through. If so remove two screws on the inside and take out assembly with the key hole, position key hole bottom, then put key side assembly with shaft through bolt portion of lock. Test the key to see if it locks and unlocks, maybe you need to position shaft 90 degrees to left or right to work, then put cover on inside house and the two screws.
May 19, 2016 | Schlage Locks & Locksmithing
I have a canon eos 20d that has become permanently attached to a canon 75-300 zoom lens. I cannot detach the lens and fear if I force it it will break the camera and/or lens. The lens is more than 5...
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed. if it dint work let me know
Regards
Smilemaker.
Jul 08, 2008 | Canon Cameras
How do I remove the 10-year old "TITAN", locking dead bolt from my front door? I removed the interior turn-handle side, but can't get the outside (keyed side) off?
if the inside is off and you unscrewed the main long throught the door screws than it is more than likely just stuck on by paint, they clamp to the door from each side with those screws, if there a no visible screws then its just stuck
Oct 16, 2014 | Kwikset Titan Single Cylinder Deadbolt
Craftsman cordless trimmer jammed
tools that become jammed from turning 1st need to be found out 4 cause of jam , and jam removed then a ck of the electicial motor for any faults inside of it need be looked at , if none found, a relube and reassembly of tool needs to be done
some common causes of tool jamming are : foreign object stuck in a tight fitting spot, lack of lubrication and tool is too dry to move , bent moving item on tool ,an hard jolt has been given to tool and some part of moving assembly has bent and become jammed tight, like dropping tool this would be a hard jolt
Jan 06, 2014 | Craftsman C3 19.2 Volt Cordless Hedge...
I just got one of these gave to me from nieghbor lock not real old and in good shape its never seen weather. When you install the battery's it trys to lock then keeps tring to lock for like 30 seconds or...
Here is the link to the installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I think that you may have the door jumper set in the wrong position for the way your door opens (door handing; see page 6 of the instructions).
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Dec 03, 2010 | Kwikset 907 907-15 Satin Nickel Smart...
The combination won't open the lock ...it takes 4 or 5 times to open the dead bolt all the way ...sometimes on the first try but mostly 5-9 tries .
You should replace your batteries as the motor that moved the deadbolt does not have enough power to move it with weak batteries. If that fails make sure the deadbolt moves freely when the lock is removed as the mis-aligned mounting will cause excessive force be exerted to move the deadbolt. See http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Sep 29, 2010 | Weiser Lock Powerbolt 1000 Lock
My AIWA TV 19-inch color is 9 years old. It is
HI,
WHEN WORDS AND PICTURES ARE BLUR,DIFFICULT TO SEE,,
ITS PROBLEM WITH LOT (LIGHT OMITTING TRANSISTOR) WHICH INSIDE TV ...
NOT OTHER PROBLEM ..JUST GO TO ECONOMIC TV TECHNICIAN.
TNKS
RABBANEES
Nov 12, 2009 | Aiwa F2000 20" TV
Deadbolt stuck on lock position
hello there:
you will need to dissasemble the deadbolt there is a plastic piece that wears out over time and once this wears out it wont work right probably best just to replace the deadbolt (sorry)
Jul 22, 2009 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
New schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
Jun 24, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Technical
The lock's fingerprint recognition technology has a failure rate of 1 in 1 million - far lower than an old fashion 5 lever mortice lock. You'd have to be flippin' unlucky for an unathuorised access. However, you should be advised that early devices have been discovered to be vulnerable to quite simple methods of deception, such as fake fingerprints cast in gels. But who do you know that will take your fingers and deep them in a gel? That's a lot of work for someone who just wants to get into your house. He'll be better off if he'll go to you neighbor's house.
Aug 27, 2008 | Deadbolt Zurich Digital Keyless Remote...
Schlage B362 619 KA4 Dbl Cyl Deadbolt Per 004 Ea Logo
100 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
