Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
  • John Tripp
    John Tripp Dec 04, 2012
    Then hold off on the water control valve. The ice maker sets the time of water valve flow. If lifting the arm on the ice maker stops the water valve then the problem is most likely the ice maker. Sorry for the change in direction. John Tripp
  • John Tripp
    here is a link to a Maytag/Whirlpool ice maker troubleshooting service manual http://appliance911seabreeze.com/whirlpo...
  • 4,654 Answers
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
Maytag ice maker floods the kitchen when water doe - 12_4_2012_9_41_08_am.jpg
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Posted on Dec 04, 2012
  • 2 more comments
  • Rodger Mitchell Dec 04, 2012
    Model # is MSD2454GR
    Water seems to shut off when the ice maker is shut off by lifting the bar, thanks
    Does that mean I need a whole new icemaker? Thanks for your help and sending me the link
  • John Tripp
    It may be easier for most to replace the whole ice maker. For some people they like to rebuild their ice maker but for most it is just easier and cheaper to replace. Thank You, John Tripp
  • 358 Answers
SOURCE: water leaks from ice maker in ice tray.
When the ice maker calls for water it'll be filling for about 7 seconds if is more the ice maker inside control board is bad , but if there's water in the ice maker all the timeeven after or before it calls for water it means that the water valve (solenoid) that supplies water to the ice maker is leaking and you have to replace it.
Posted on Apr 27, 2009
  • 159 Answers
SOURCE: no water pressure for ice maker or water despenser
Sounds to me that you attached a bulet piercing valve to a cold water pipe. If you did I would say the tiny hole that the valve put into the pipe has blocked up and causing your low water pressure. I have sen this problem a million times with that type of valve. You could try to close the valve and then open it back up. Sometimes this will clear the hole. If not I would replace the valve with the type of valve you have for your sink. there better in every way. You may need to have a plumber do the job for you but you will never have this problem again. Good luck
Posted on Jul 12, 2007
SOURCE: no water for ice maker
make sure wire is in down position this is like the on and wire up is off
Posted on Jul 14, 2007
woodchuck789
  • 4066 Answers
SOURCE: not making ice
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Posted on Sep 24, 2009
  • 5370 Answers
SOURCE: Ice tray won"t fill with
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Posted on Apr 26, 2011
Maytag msd2758ges ice maker squirts water
Sounds like the water solenoid is not shutting off cause once the tray fills it should stop sending water located in the back bottom with the water lines connected
Mar 24, 2013 | Maytag MSD2756GES Side by Side...
Why is my ice maker filling up my ice tray with water then freezing it like a block of ice?
There are some adjustments that you can do if you carefully follow the instructions in the video below. I also have a Whirlpool Ice Maker Troubleshooting and Service Manual upon request. Your 67003753 Water Inlet Valve=> 67003753 Water Inlet Valve could be leaking and creating this block of ice. For most Whirlpool/Maytag brand ice makers is is cheaper to replace the core module part number=> D7824706Q Ice Maker Module. Reason being the individual parts add up to more than the cost of all those parts together. Now if interested you can request a Whirlpool Ice Troubleshooting Service Manual by filling out the capsha=> HERE Reason I don't place the manual's here because Whirlpool ask me not to do so, but I will be glad to send you one. The manual is the solution but the most complete module or replacing water valve is the cheapest route. Below is how it is explained a little simpler. If I can help you in any way please ask, Thanks, Sea Breeze
If helpful please rate this solution.
Jun 21, 2011 | Maytag MBF2256H Bottom Freezer...
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
Ice maker water line doesnt shut off
If the icemaker did not stop right in the spot where the water fills the tray, without completing the cycle, you have an icemaker problem, but that is highly unlikely. More likely is that the water fill valve (the part right where the water line hooks onto the refrigerator) will have to be replaced.
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Feb 07, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Ice maker flooded the house
how much water we talkin here a cup or gallons?? the icemaker will only call for water after dumping cubes,SHOULD at least, if only a cup of water or so id say the ice maker has an issue and needs replacing(its an entire module), there is a valve behind the machine energized by the ice maker, if htat got stuck open in which case water continued to flow overnight i would repalce both ice maker and valve
Mar 01, 2008 | Whirlpool GD5SHAX Side by Side...
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
Dec 31, 2006 | Amana ARS266ZBS Side by Side Refrigerator
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
353 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
