This questiion is concerning the where-a bouts of the Ballast that operates the two F32T8 lamps in a Food Merchandisor, its a Tor Rey model TEM-200
  • Gary White Dec 04, 2012
    I don't understand why, FixYa thinks my question, or problem is with a PRODUCTION TV !!!
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Somehow it got listed in the wrong area---it is a glitch which happens here from time to time---you can email staff@Fixya.com to see if they can correct you..
Posted on Dec 04, 2012
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Where Is the Ballast.
The ballast is on the other side of the lamp compartment. the lamp plugs into the two short leads that are attached to the ballast. Its a small circuit board.
Posted on Jun 13, 2008
SOURCE: Need to buy a lamp & Ballast
http://electrified.com/Catalog/Items/?CampaignID=Froogle&ItemID=35508
Posted on Dec 20, 2008
Why red light is on ?
Its the most common poblem with the ax 100-200 projector.Many a times only the ballast requires to be replaced.yet on may occasions both mainboard and ballast requires replacement. its best to confirm with a good known working ax200 and replace first the lamp, ballast and the mainboard.panasonic ax 200 lamps also have failed premature as per my experience.
May 04, 2014 | Panasonic PT-AX200U Projector
BALLAST PART No FOR A SAMSUNG SP50L6HX PLEASE HELP
Google that model number with ballast or lamp ballast to locate the part and its number. Usually the color wheel will not operate if ballast is not working---Lamp comes on and stays on the Ballast is good.
Nov 06, 2012 | Samsung SP50L6HX 50" DLP HDTV
TV Model: Sony Wega KDF-55E2000 Projection lamp warning is on..and today a light red bar appeared at the top of the screen and light blue on the bottom..is this because the projection lamp needs to be...
Hello
There are two possibilities for this fault with Sony Projection tVs. The first is with the lamp itself. The second one is with the lamp ballast baord. Replace the lamp ballast board first. Because, it there is any internal winding short in the inverter transformar of the ballast board this type of fault can occur. you have to replace the ballast baord along with the new lamp anyway. Therefore, replace the ballast board first. If this help you, there is no need ot replace the lamp. Picture of the ballast included here for you to compare.
gopakumarg43_36.jpg If replacing the ballast dis not help you, change the lamp too. OK.
Aug 31, 2011 | Sony KP-57XBR10 57" Rear Projection...
I have a 2006 Thomson/RCA ModelM50WH72S TV that we have replaced the lamp, it still does not work and a technician has told us that we need a light engine for it. How can we locate one?
have the same tv,, power light blinks, book said it was bulb, bulb didnt fix it,took it to tv repair shop, they found a bad capacitor, replaced it with a higher heat range capacitor, this capacitor was on the power board for the lamp circuit, repair was $200, not bad since i paid $1500 for the tv, other than that issue, just replaced a couple of lamps
Dec 28, 2010 | Televison & Video
Nec Lt245 power light yellow - orange status blink red, no image, no light coming out of the projector
- Unplug the projector for a full 4-5 minutes.
- Plug it back in and wait for the ready light and try it again.
If the above fails, replace the lamp.
If that also fails, it is likely a bad ballast.
Thanks,
Tor
Aug 27, 2009 | NEC LT245 Multimedia Projector
My PT-61LCX65 all of a sudden turned itself off and the Lamp indicator LED is blinking once every 5 sec. It will not power up. Can it be the lamp?
That is most probably the lamp. In some case the lamp is fine and the problem is the lamp high voltage board (ballast board).
The most coomon is always the lamp. The lamp cannot be tested . The ballast board must be tested by a technician.
The normal operation in this case is replaceing the lamp that cannot be tested. then, if you are within that 2% of the cases with ballast problem you replace the lamp power board or call a technician.
You can find parts here.
May 03, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
SP-LAMP-LP3E powers off in 5-20 secs after inital power on
if the new lamp doesn't have a problem, then it's not the ballast, it's just a bad bulb. especially if you didn't get it from infocus. the cheaper lamps don't last long. you get what you pay for.
Dec 23, 2008 | InFocus Projector Lamp for LP340, LP340B,...
Jun 13, 2008 | Zenith D52WLCD 52" Rear Projection...
Ballast Unit
Ballast is nothing but it is lamp power unit so here high voltage operating unit. While change the unit please check the voltage ratting and model. connector model and then replace.
Regards,
prakash
Apr 03, 2008 | NEC Replacment Lamp Projector Lamp for...
BALLAST
WARNING...The ballast can output 3000volts when it initially fires the lamp. Without the proper test equipment you could injure or even kill yourself. You've verified that the lamp is good and now suspect the ballast?
Apr 16, 2007 | LG 52SX4D 52" HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
