Question about DCS RDS-364GD-SS Dual Fuel Kitchen Range
DCS 4 burner plus griddle Range..oven doesn't heat
My DCS 4 burner Range plus griddle (natural gas)..the oven doesn't heat. The stovetop works fine, but the oven doesn't work/heat up. It was in my house when I bought it so I do not have a manual. Thanks.
  • 1 more comment
  • CSTMoose Mar 12, 2009
    I have the same range, DCS 4-burner with griddle, and I had the same problem. The service guy replaced the igniter and the thermostat, and the oven works now. This is the 2nd time in 11 years I have had the oven igniter and thermostat replaced.
    I do not recommend this range. In 11 years, he oven has gone out twice (see above), the oven door hinges needed to be replaced, the griddle has gone out twice, and the broiler has gone out twice. When the griddle or broiler do work, they are sketchy when they light: There is a long pause, followed by a large ka-wooomp when the gas finally lights.
    Maybe the newer DCS ranges are better, but buyer beware.
  • Anonymous Mar 16, 2014
    Need to locate replacement thermostat for a DCS natural gas commercial oven. Oven continues to heat despite setting thermostat at a lower temp
    DCS6 burner commercial natural gas oven thermostat needs replacement. model36 6 1N. need to locate part
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Posted on Aug 10, 2009
I don't have a solution but a follow up question... when your oven went out, did the broiler still work? My stovetop, grill plate and broiler all work fine, but my oven doesn't light. When it did work, it had the same delay, kawhooomp sound described above. The delay and noise became worse and worse until it stopped lighting altogether.
Posted on Oct 11, 2009
How do you repair oven that won't fire?
Given that its gas, I would advise you get a competent person to check it out. Propane gas and sparks don't mix. There are things in the owners manual you may feel confident enough to check, if not, leave it to a trained person.
Aug 29, 2014 | DCS Professional RDU485GDL 48" Pro-Style...
Self Clean won't start
Sounds like a control board problem
Nov 10, 2017 | DCS RGU-486GD-L Range 48", 6 Burner,...
DCS RGS slow to preheat
You didn't state whether you used a DCS conversion kit or not. I was able to find conversion instructions for a model similar to yours (not an exact match) but it will give you an idea as to what all is involved.
DCS RGSC 305 Instructions Manual
Dec 14, 2017 | DCS RGU-364GL-N Professional Series 36"...
I have 48 " 6 burner stove natural gas.Stove is
the glass in the ovens should not crack when self clean is used. it could be that there was a minut crack in the glass or a build up of moisture in between to door windows that expanded at the extra heat but this should be brought up with the manufacturer for replacement.
I hope this was useful.
Jan 05, 2011 | Viking 48" 6 Burner, Griddle Professional...
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Both ovens do not heat max heat is 150 to 200
good luck.  We have the same range and have had issues with the ovens since the range was installed.  The overn does not heat evenly on convenction or bake.  Thermadore doesn't stand behind the product and neither does the distributor.  They tell us that Thermador isn't standing behind the product so there isn't anything that can be done.  We spent $8000 for an oven that burns the back corners of everything we bake.
Mar 21, 2007 | Thermador PG484GGEBS Stainless Steel...
Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Feb 12, 2007 | Thermador PG486GEBS Stainless Steel...
DCS RDS-364GD-SS Dual Fuel Kitchen Range Logo
1,075 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
