Question about Sony Playstation 3 (PS3) Console
There is a slight buzzing sound on my TV
With the PS3 connected via hdmi to my 58"lcd, there is a buzzing sound and a slow rolling shadow going up the screen. The shadow takes about 5 seconds to go up the screen and is only a little darker, but noticable. It happens whenever the ps3 is connected, even if it is turned off with the back power button. Is it the tv, console, or hdmi cable?
  • aries009 Jan 12, 2009
    same basic problem. i did read that if you get a two prong adapter and put that on the ps3 cord and then plug that into the outlet it should solve the lines in the screen haven't tried to see if it will work on the buzzing noise.
  • tango30dui Jan 12, 2009
    PS3 is plugged into componet video1.  first I was hearing a slight buzzing noise and now the color is purplish and the buzzing is louder.  The PS3 is connected to a Bose receiver.  Tried different inputs on for both the video and audio, no change........hoping its the A/V cable, and ideas....???
Sounds like your HDMI cable is crappy.......if its aftermarket, make sure its a good quality......you can check the resistance of the cable with a multi-meter in the "ohms" mode.  The cable package should have the ohms value on it, if the cable is out or range, thats your problem.......
Posted on Jan 12, 2009
  • 3 Answers
Its the tv dude cuz i put the yellow white and red on a small old sony tv and it made the same noise and everything but then i changed it into another t.v. about 73 inches and it worked fine with an hdmi change the t.v.
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Sound shutting off in the middle of gaming
Is the HDMI lead just just coming slightly loose? Otherwise I can't think of anything else - it's definately the lead. If it isn't because it's coming loose, I'd recommend getting a new lead.
Jun 09, 2008 | Sony Playstation 3 (PS3) Console
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Shadowing on screen
You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
bimmerhp
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Dec 27, 2007 | Sony QUALIA 005 46 in. LCD Television
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Sony Playstation 3 (PS3) Console Logo
256 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
