NEED HOOK UP INFORMATION
SOURCE: am trying to hook up an older kenwood home stereo
Okay you are going to need 5 sets of RCA cables of 3 foot lengths. Ensure the KM-207 is adequately ventilated unless you want to burn up the KM-207. Next you will want to place the KC-207 near the KM-207 and connect the "Output to Amp" from the KC-207 to the "Input" to the KM-207. Now you may stack the KX-77CW, the DP-M97 and the KT-87 Tuner in no particular order. I tend to place them sideways so I may access them just in case I don't like how it is set up. Unless I can access them from the back. "Output" or "Play" from the DP-M207 goes into the "CD Input" in the back of the KC-207. "Output" or "Record" on the KC-207 "Tape 1" goes into the "Input or "Record" on the KX-77CW. "Output"or "Play" on the KX-77CW goes into the "Input" or "Play" on the "Tape 1" of the KC-207. "Output" on the KT-87 Tuner goes into the "Tuner Input" on the KC-207. Here is a trick to help you new stuff uses color codes such as White or Blue RCA cable ends, and Red RCA cable ends to indicate White or Blue for Left channel and Red for Right channel. Now you didn't indicate how to hookup speakers so I will not assume you are concerned about anything but using headphones for listening. I hope this has been of assistance.
