Question about Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat
How to correct error code C-7 on my RTG-74PVN Rheem Pronto
Hot water heater kicks off when using hot water. Monitor shows C-7 code.
I cleaned both water filter and air intake filters. What else can I do to fix this problem?
  • 2 more comments
  • pculotta3 Jan 12, 2009
    My unit has worked great for about 1 1/2 years. Starting about a week ago, the unit would should off after using it for 15 minutes or so. Sometimes I would see error code C4 or maybe C8. Now, it will stay on for about 30 seconds and show error code C7.
  • vinnyboy88 Feb 26, 2009
    I have the same problem either C7 or C8 error code. And no, the manual has no information for these codes.
  • Scott Magill May 11, 2010
    There should be another number after the c-7. Have you cleaned the inside of heat exchanger? You could have a build up of lime inside? If you have your manual i think page 36 tells you error codes. you can call rheem customer service at 18004328373 you will need model and serial # before they will help you but they will help you trouble shoot problem if you have all the information.This will probaly be quicker for you to get it fixed? if not let me know and i will try to help you out.
  • Anonymous Mar 20, 2014
    The hot water runs 3-5 minutes then it kicks off with error codes c7-c8. I cannot find what these 2 codes indicate
I had the same problem and called the manufacturer. The error code C-8 was followed by the number 76. They told me to disconnect the thermostat/digital display from the main unit. This was fairly simple to do by removing the front panel. The unit works steady now without shutting down after a few minutes. The help desk told me that the main circuit board needs to be replaced for the unit to work with the display and that they would mail me one asap. At least we have hot water again.
Oakville, Ontario
Posted on May 24, 2009
    Problem Solver:
  • 4 Answers
You are missing another portion of the error code. Example: the remote flashes C-7, then flashes 13. The manufacture can assist you. Call them at 800-432-8373. Have your serial & model number.
Posted on Mar 10, 2009
Rheem RTG-74PVN-2 code c776
Communication fault with remote, but also bad PC board.
Copy following link for troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 13, 2012 | Rheem Tankless Hot Water Heater...
Rheem Pronto water heater Error code E1
Before calling service technician, open following link for troubleshoot resources include Rheem chat, error codes, and regular maintenance manual, and possible product manual:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Clean the water filter as shown in product manual.
Error E1 is not specifically shown for Rheem/Pronto tankless.
1 is usually related to water flow.
E errors are related to temperature, so E1 can be temperature sensor failure on hot water pipe.
E errors can be loose/bad wiring or part failure.
Error codes are considered start-point for troubleshoot.
Each tankless manual recommends cleaning the water filter monthly, deliming heat exchanger yearly, and cleaning combustion chamber and burner parts yearly.
Regular maintenance can prevent most common error codes, but the cost and nuisance will outweigh expected $1-8 monthly savings on gas bill.
The requirement for continual maintenance should signal folks that tankless are not effortless hot water as described in tankless promotion.
Solve most tankless problems same day, yourself, any brand, using minimal tools for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 02, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
http://www.fixya.com/support/t3444443-paloma_tank_less_water_heater_flashes
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Rheem rtg-74pvn-2 tankless water heater installed in 03/09. Intermittently the hot water stops when only the hot water tap is on. No error codes appear. Bill W.
Before calling service technician, open following links for resources including Rheem chat and possible manual:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Crossover.html
Typical tankless manual says to have yearly service which includes checking household plumbing, gas supply, vent and condensation, check sensors for loose wires, clean and inspect burner parts and ignition factors etc.
Aug 04, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem tankless rtg 74pvn - heater hot water shuts
This is something you will have to contact rheem about due to the fact you don't have a fault code
Jul 13, 2010 | Rheem Tankless Hot Water Heater...
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I have a Paloma PTG-74PVN and I ain't getting any hot water and its showing c2-11 error code. How can i fix this problem
could be overheat stat or fan check the little hose at the fan area for pinhole next choice diaphrapm valve then micro switch best of luck
Oct 23, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Pronto Hotwater Heater Error
Unplug unit from wall. Disconnect remote wires from circ board, and let unit set for about 5 minutes. plug back in. run water and see if unit comes on.
Jun 16, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat Logo
2,692 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
Mike Cairns
Mike Cairns
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
