Question about Canon IR2535 Copy Machine
HOW TO RESET E00000 CODE ON CANON IR2535 COPIER
  • 10 Answers
* 2 8 *
Posted on Feb 27, 2013
Error e000002
addntl func
2&8 (at the same time)
addntl func
at this point the screen should change. If not hit reset button and try again.
copier
func
clear
err
ok (in the lower right hand corner of screen)
Turn power off and back on. (black switch on the right lower side of copier)
DO NOT ATTEMPT TO DO ANYTHING ELSE IN SERVICE MODE! YOU CAN REALLY MESS UP YOUR COPIER BEYOND REPAIR IF YOU DO!!!!!
Mar 09, 2015 | Canon IR2535 Copy Machine
How to solve Ir2535 copier E000002 error codes
canon ir 2535 Error E000003 How to removed
May 07, 2013 | Canon IR2535 Copy Machine
How to reset error code E00000-0010
This is the standard proceedure for the Canon ImageRunner Copiers and all that I'm sure will follow: Press the " Additional Function " key, then press " 2 & 8" at the same time, then the " Addtional Function " key again. You should now see the service mode screen. Press " COPIER ", then " FUNCTION, " then " CLEAR, " then " ERR ", then " OK. " This will clear the code out of the copier's memory. Please be careful in service mode becuase you can do very distructive things in this mode that may take a Canon qualified technician a long time to resolve. Power down the copier at the main power switch, wait a few seconds then turn the copier back on. If the error comes back then you have a fixing assembly problem that will have to be resolved before being able to use the copier. Good Luck.
Sep 13, 2012 | Canon imageRUNNER 5570 Copier
Whay does an error E000000-0010 on a Canon IR5055 mean?
A E00000-0010 means you have a problem with the fuser unit. I would try to rest the error code first in service mode. If you had a power problem, the copier may give that error code. If it will not reset, you have to fix the fuser unit first.
Apr 04, 2011 | Canon Office Equipment & Supplies
Canon ir6800c error E00000-0030
after power on temp does not reach 50 deg C within 420 sec check main thermistor thermal switch and heater then enter service mode *28* copier function clear err and then retstart copier
Sep 11, 2009 | Canon imageRUNNER C6800 Copier
Have a canon ir-5570 w/ error E00000-0010 will not allow me to reset code Any ideas? Tried the reset procedure of ad.funct 2 & * adfunc will not go into mode
press ad.funct. then press 2 & 8 keys at the same time,
then press ad. funct. , copier display shows setup mode go to (function)
tab and press clear error.
Aug 20, 2009 | Canon imageRUNNER 5570 Copier
E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
Mar 10, 2009 | Canon imageRUNNER 4570 Copier
Canon iR c3220 problem code E00000 0211 HELP!
problem w/fuser unit.
either it's not turning on or the temperature is not correct.
check thermistor, thermofuse, lamp
Oct 09, 2008 | Canon imageRUNNER C3220 Color Copier
Canon 4570 E00000
You need to reset the code by clearing the error memory phone me on 07764303923 i am in england and will tell you how to do this
May 06, 2008 | Canon imageRUNNER 4570 Copier
Canon IR2535 Copy Machine Logo
293 people viewed this question
old marine
old marine
