Question about Canon PowerShot A520 Digital Camera
Camera does not go on
Push power button to take photos and Canon comes on screen for 1 second and then screen goes blank. Camera lens does not move out to open.
Push power to show photos, and CANON comes on screen for 2 sections and then E 18 appears in lower left of screen and then screen goes blank
  • Canon Master
  • 4,738 Answers
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 11, 2009
Get message Lens error, restart camera
Not much you can do. Switching off the camera and then on, is like a cod boot from a computer.
You could try to remove the battery for a few seconds, and then reinsert it. Then you should investigate why the lens stays out. Is it because of a mechanical problem, or came some dirt between the barrel, while the camera got wet? Try to remove any obstruction. feel if the lens can move by gently moving the barrel a little. If it goes. Don't apply force, because you could damage the mechanical or electrical parts in the lens barrel.
I hope it works. Don't forget: the battery should be charged fully.
May 12, 2014 | Canon Cameras
CAMERA FROZEN..nOTHING WORKS. sAYS "LENS ERROR. rESTART CAMERA"
try to remove the ring over the lens- this is just alluminium ring. I had same problem when my camera felt on floor... i thought its wrecked ... but it was 4 months ago and since that i made thousands of photos and its working fine. Remove the ring, i did it by forcing it, twisting and when removed - lens error was not appearing. I fixed that ring and placed back with a little super glue. Everything is ok.
May 21, 2010 | Canon PowerShot SX20 IS Digital Camera
I have an A560, LCD screen goes blank
try the display button if thats not the problem, then ccd lens sensor went bad and need to be repaired by canon http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=183&modelid=14904#SupportDetailAct
Sep 13, 2009 | Canon PowerShot A560 Digital Camera
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
CANON POWERSHOT S2 IS 5 MEGA PIXELS
I bought mine 2 1/2 yrs ago too. Found this solution on this site and tried it. It worked perfectly.
Turn to TV mode, set the exposure to 15 seconds by pushing the little "arrow dial" until you have 15"
Push the button to take the picture.
Wait 7 seconds from when you push the button, then turn over and open the battery door while it is "taking the picture."
Close the battery door and turn back on.
I did this three times and the last time, it worked and the iris became unstuck.
Then I took a million pictures to get the iris moving.
Jul 11, 2008 | Canon PowerShot S2 IS Digital Camera
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
Canon A75 stuck between ON & OFF after uploading photos
My Canon A75 has the EXACT same problem. I have always handled it with care. When I was taking photos with it, the camera suddenly started shutting down without a low battery warning. It just started shutting down, but it stopped with the lens still sticking half way out. Like yours, the top green light flashes when I try pressing the power button. Any ideas?
Dec 16, 2006 | Canon PowerShot A75 Digital Camera
Canon PowerShot A520 Digital Camera Logo
133 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
