Question about KitchenAid KSRB25FKSS Side by Side Refrigerator
Need auger motor harness connector for kitchenaid KSSC48QTS00
  • jbullen1
    jbullen1 Dec 06, 2012
    That looks to be the harness for the ice maker......Auger motor is located in the freezer door. The actual wires going into the connector were coroded from ice build up and the came out of the connector.
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
Posted on Dec 04, 2012
2 Suggested Answers
  • 25 Answers
SOURCE: Ice Dispenser kitchenaid KSRP25FNSS
first make sure that there is not ice clogging the auger. check that connection to the auger motor is secure. If it appears to be fine you will need a volt meter for the following steps. If you are not comfortable using this equipment or do not want to buy one call a repairman. If you choose to continue remove the leads from the auger motor. Configure the meter to read ohms and place the leads across the motor connections. The meter should read some resistance if not the motor is either shorted or a lead has burned completely due to a short. If the motor is fine configure the meter to read volts. Look on the motor and determine if it is AC or DC and configure the meter for this. Connect the voltmeter leads to the motor feed wires and press the ice despense button. If no voltage is observed check the switch for continuity. Replace any faulty parts. If this sounds foreign to you call a repairman.
Posted on Mar 27, 2008
Kitchenaid KSRS25 Ice dispenser blades get stuck
Greetings,
In looking up this partial model # KSRS25, it shows you have
the model with the large ice bin inside the freezer.
My question to you is: Does the auger motor run when you
push the ice lever?
2 trouble prone parts on this model. Both in the case of NO
auger motor activation.
#1 broken pin that hold the micro-switch on to the switch bracket.
Item # 15
1690545?addlogo=false
Next #2 and the Worst, A Broken Blue wire or wires in the wire loom
under the freezer door hinge. Un-repairable new door needed if still
available.. You have to get creative restoring the power.
So before I continue, Does the Auger motor Run?
And if it does, remove the bin and close the door switch that turns the
light off, and tape switch shut. With door open and ice cradle pushed
in watch the auger drive fork turn? Is the the key hole stripped in the
fork.(rounded out) May need the fork or motor. #9 & #2
1708855?addlogo=false
May 28, 2013 | KitchenAid Architect® Series II KSRS25RS
Our ice maker makes ice, but the dispenser just grinds and clogs up with ice shavings.
Hello there,
When there is a problem with the motor that opens and closes the dispenser is when you will be experiencing such problem as having the ice maker making ice but not dispensing them
Most likely frozen up, known problems with this on kitchenaid. Try removing the auger motor and thawing it to see if it will then run.Your auger motor may be frozen, use a hair dryer on it and see if it starts turning again.
The best, if not easiest way to access the auger motor is pull it out. It's just four screws, two on each side of the fork assembly. The white plate and auger motor will come out together. There is a quick disconnect for the wires.there are boot kits to install over the motors to prevent this or just put it into a plastic zip lock bag with the shaft poking thru a hole in the front.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | KitchenAid KSCS25FKSS Side by Side...
Our power went out a week ago and since then our Kitchenaid side by side will not despense ice from the door,it makes ice but will not dispense. We cleaned it our thinking ice had melted and then refroze...
The auger motor is frozen. Open the freezer door and remove the 4 screw holding the auger motor. Unplug the harness. Put it on the counter and use a blow dryer to defrost it. Shake out the water thats inside. Do this until u think all the water is out, then put it back in door and plug it in. You should be good from then on. If you loose power again. Remember to remove ice bucket or water will leak into motor again.
Jul 17, 2011 | Refrigerators
Replacing auger motor
Hello, Replacing the auger motor is not hard after removing the ice bucket there are two screws under the housing that holds the auger bracket in place remove the two screws from under the bracket and lift up on the whole assembly reach under and unplug the harness the whole metal housing comes out. then remove the auger drive from the motor it is counter clockwise to take it off then remove the four screws holding the motor. thats it hope this helps. please rate me it helps.
Jun 07, 2011 | Electrolux EI26SS55GS Stainless Steel ...
Icemaker is making ice but the ice dispenser is not working
Check the ice storage container. The ice dispenser will not dispense ice until the first supply ice has dropped into the ice storage container.Remove excess ice from the back of the ice container. Make sure ice cubes are not jammed between the ice maker and the back of the ice container.
The auger won't engage or turn to dispense ice.Remove the ice bucket and with a hair dryer warm up the inside where the fork is that turns the auger in the bucket and try it and if this does not help then you will have to replace the auger motor ,, chances are the motor is just froze up .--------
If there is nothing jammed then try this./Remove the ice bin out.And then clean the ice bin.
Rotate the auger with your hand.If its hard then there is problem with auger motor.If the auger is not rotating fine then its faulty auger motor or the auger motor is frozen,if you notice ice getting collected there.
Take a hair dryer and blow hot air on the auger motor for few minutes.Take care you dont blow hot air continuously.
But if that is not helping then disconnect auger motor connecting wire wait for 2 minutes clean the connector and reconnect the connector back and see.If that is not helping at all.Then,replace the auger motor.
To see how auger motor looks.Please click the link below:---
http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=3965455&image=0
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | Frigidaire FRS26H5AS Side by Side...
When i depress the paqddle to dispense ice the auger does not engage and no ice will come out
Make sure the ice bucket is fully seated into the space below the ice maker where it rests, if not in all the way, the auger cannot engage and or the switch that tells the auger motor that the bucket is in place will not be triggered.
Good Luck !
Mar 14, 2010 | KitchenAid Architect ® Series II KSRX25FT
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Mar 09, 2009 | Toshiba E-STUDIO 550 Copier
Mar 27, 2008 | KitchenAid KSRP25FNSS Side by Side...
Ice dispenser not working
Pull out auger & try With Out auger in place with door open and see if auger motor will spin with out auger and tray IN.. you with have to push door switch in to get auger to work .. with door open
Sep 12, 2007 | KitchenAid Architect ® Series II KSRX25FT
KitchenAid KSRB25FKSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
