Question about Scotts Miracle Gro Liquafeed Sprayer 6 Refill Combo Pack
Won't spray...how can I mix it with water to put in one of the older Miracle Grow sprayers? I need proportions
Spray comes out but the level of the bottle never changes which would indicate to me that it is not working. I have opened two different bottles thinking there was something wrong with that one bottle...now I have two bottles and I need to know what proportions to mix in the old type miracle grow sprayer in order to feritilize by spray.
2 Suggested Answers
mark24354
  • 776 Answers
SOURCE: I have not used my
Tim,
The tube that dips into the bottle is likely clogged. I think it pulls out without too much force. You can rinse water through it.
The miracle grow is very soluble in water so it should take too much rinsing before it clears.
You can also let is soak overnight.
If the tube does not come out easily, don't force it! Soak the whole thing in a 5 gallon bucket of water over night and try it in the morning.
You can also check the sprayer end of the unit. Unscrew it and rinse it well. Be careful that no gaskets/o-rings fall out. I don't think there is one there, just double check and take it apart over a table to be sure (don't unscrew it in the yard).
Good luck.
Posted on May 21, 2011
How to connect miracle grow 3 in 1 sprayer to hose
you need to either purchase or find (if you have one) a female connector i think, if i remember correctly. my hoselock connector worked ok and plug it in like you would any other hose compatible tool
Jun 12, 2014 | Computers & Internet
Can't get wash fluid to mix/spray out of Honda
I BELIEVE YOUR SPRAYERS ( JETS ) ON THE WINDSCREEN ARE BLOCKED. TO CONFIRM JUST PULL OFF THE HOSE LINE BY THE JETS AND ATTEMPT TO SPRAY.,IF THE WATER COMES OUT QUITE POWERED,THEN THE NOZZLES ARE THE FAULT. WHAT TO DO,IF YOU CAN REMOVE THEM AND DROP THEM IN A VINEGAR FOR FEW HOURS OR IF YOU DO NOT USE THE CAR FOR A NIGHT AND THE NEXT MORNING BLOW THROUGH WITH A PRESSURE AIR FROM THE SPRAYING JET SIDE TO THROW OUT ANY REMAINING. FIT THEM ON AND TRY AGAIN. ALWAYS IN THE MIXTURE OF YOUR WASHERS PUT SOME ALCOHOL.
Sep 02, 2012 | Cars & Trucks
My ryobi 18 volt paint sprayer won't spray paint or water out
when finished spraying it must be sprayed with water and then use a solution ,you can buy to spray through it to stop the works clogging up . its probably clogged right up.
Mar 18, 2012 | Ryobi P630 One+ 18V Cordless Power Paint...
The liquafeed did not dispense much during about 10 minutes of spraying, (Only about 1/4"of Liquafeed was dispensed.
I'm sorry to hear about the problems you are having with your LiquaFeed Sprayer. Your water pressure needs to be at least 45 PSI. If your garden hose is longer than 50 ft, this can lessen the water pressure. If there is any foreign matter or crystalization on the bottle or the sprayer where the bottle inserts, this will need to be soaked in warm water, as it may be clogging the sprayer. With the bottle of LiquaFeed apart from the sprayer, squeeze the bottle to see if any product comes out. If none of these troubleshooting steps help, please call us at 877-465-5160, and we will be happy to assist you further.
Hilary @Miracle-Gro
Sep 19, 2011 | Scotts Miracle Gro Liquafeed Sprayer 6...
This is the second feeder I've purchased that quits spraying water (anything more than a dribble) after 3 or 4 uses. Even replaced the washer today. There are 6 refill bottles in my garage, but no...
I'm sorry to hear about the problems you are experiencing with your LiquaFeed Sprayer. You can always try to soak the sprayer in warm water for about ten minutes, and wipe dry. If this doesn't help, please call Miracle-Gro at 877-465-5160.
Hilary @Miracle-Gro
Aug 10, 2011 | Scotts Miracle Gro Liquafeed Sprayer 6...
Can I dilute Scotts Miracle Grow for use in my Ortho dial spray bottle?
Yes, you can use Miracle-Gro Water Soluable Plant Food in the Ortho Dial N Spray hose-end sprayer. Simply set the dial on the Dial N Spray to 4 ounces. The label rate for Miracle-Gro All Purpose Plant Food is 1 tablespoon per gallon of water. To make 8 gallons of finished spray, measure 8 rounded tablespoons of plant food into the Dial N Spray jar and fill the jar with water. Mix thoroughly. Set the dial at 4 ounces. When you have sprayed until jar is empty, you will have applied 8 gallons of properly diluted spray. Hilary@Scotts
Jul 23, 2011 | Garden
What setting do I use on my ortho dial and spray for fertilizing plants and vegetables outdoors? Thanks
If you are using Miracle-Gro Water Soluable All Purpose Plant Food in the Ortho Dial N Spray Hose End Sprayer, follow the directions below :
  • Set the dial to 4 oz
  • The sprayer can make up to 8 gallons of spray. Add the correct amount of product to the jar for number of gallons you wish to make. (Example - The dilution rate is 1 tablespoon per gallon, and you want to make 8 gallons, put 8 tablespoons of Miracle-Gro Plant Food in the jar.)
  • Multipy 4 by the number of gallons you are making and fill to that oz line (Example - If you are making 8 gallons, 4x8=32 so fill to the 32 oz mark with water).
  • Prior to spraying, mix product around in the jar until granules are dissloved.
  • Spray until the jar is empty.When it is empty, you have sprayed 8 gallons of product.
If you any questions or if you are using another product, please give us a call at 800-225-2883, and we will be happy to figure out a setting for you!
Jul 05, 2011 | Garden
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Scotts Miracle Gro Liquafeed Sprayer 6 Refill Combo Pack Logo
85 people viewed this question
Top Scotts Garden Experts
Rod Doney
Rod Doney
JOHN PACE
JOHN PACE
Are you a Scotts Garden Expert? Answer questions, earn points and help others
