Question about Refrigerators
Kelvinator fridge-impression, 350 twin air no frost totally cfc free.Water drainning inside but can't tell where from.A.Cox
2 Suggested Answers
  • 1196 Answers
SOURCE: I have a Kelvinator 2
he reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Posted on Feb 26, 2011
Fridge-kelvinator 380 impression series 380 frost free
sadly no question posted gets no answer . we are not mind readers
Jan 14, 2017 | Frost Refrigerators
How do I stop food freezing in the main part of my Kelvinator Twin air no frost 500 series refrigerator
there is a dial inside the refrigerator side to turn the temp up or down . rotate the dial to a lower number for warmer
Aug 31, 2016 | Kelvinator Refrigerators
Kelvinator impression series 500 fridge leaks
The other end of the drain is located in the back of the machine. Remove the cover in the back that covers the compressor, condensor fan motor etc, the drain pan is located back there, and the drain is usually somewhere near the fan motor so that the heat from the compressor can evaporate what water does drain. The best way to fix the problem is to unplug the machine and let it thaw for 24-48 hours. Its a pain but its the easiest and most thorough.
Apr 27, 2012 | Refrigerators
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge and freezer will not cool down
69....hard to know from here. What heats up and becomes quite humid? Newly restarted refrigerators take about 12-24 hours to cool down. They should be opened very infrequently during that period, if possible.. Do you hear the compressor and fans? Have you properly set the cooling controls?
Dec 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
