Sanyo MODEL DP46848 Have this spot on front left of screen.Is this defect repairable. Any idea on how much to repair.Thanks
    Genius:
  • Televison & ... Master
  • 2,432 Answers
The cause it could be bad parts at the t-con board or has a loose connection going to the t-con board. before you come up with parts replacement you can re seat first the lvds cable going to the t-con board for the lcd panel. the t-con board is mounted underneath cover with metal shield.
Posted on Dec 04, 2012
  • 1779 Answers
SOURCE: DO THE SANYO DP42848 AND THE DP46848 LCD TV 2008
No boards in those models interchange with each other. Totally different.
Posted on Jun 16, 2011
SOURCE: My Sanyo DP46848 LCD TV display goes black when turned on.
My mother's was doing the same thing (purchased 2008). Put up with it about 6 months and took it to a repair shop. Bottom line - the display panel has a flaw in and will cost more to replace than the tv cost. See about it now it yours is still under warranty.
Posted on Nov 22, 2010
SOURCE: My Sanyo DP46848 has been having half of the screen
The left side of my tv is going black. Why is it doing this?
Posted on Nov 30, 2010
taran_2005
  • 10515 Answers
SOURCE: I have the same problem,
I am sorry to hear regarding the trouble. To start the conversation, i would like to inform you that there is NO recall as of now for this model. Bad LCD panel is not a common issue with this unit, it's almost with most of the brands. We always urge customer to buy an extended warranty. You could report the same to BBB or raise your voice against Sanyo, however the only possible solution is to call Sanyo and see, if they are willing to repair this set for you. If you send the unit to a local repair shop, it would cost you more than $1000.Call Sanyo and tell them that it is only a month after warranty and you have spent so much money on it. This usually works with most of the major brands including Sanyo and Sony. If they are still not willing to help you, you could contact their customers relations or write a letter to them seeking a resolution. Following this would be able to help you to get this fixed.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 02, 2011
  • 10 Answers
SOURCE: My DP46848 Sanyo LCD TV when turned on until it
sorry but the lcd panel is probably duff
Posted on Jun 08, 2011
47in sanyo flat screen gets a black shadow across it got to tap it to make it stop but happens alot . model DP46848
You have a defective LCD panel tab connection. The only permanent fix is to replace the panel. A replacement panel will cost more than a new set. I had the same problem with the exact same set.
Feb 08, 2013 | Sanyo DP46848 LCD TV
Sanyo 46" LCD MODEL DP46848 any sugestions on how to repair do it yourself or have it done by tech,Is it worth it?
i would say buy new as it sounds like your whole datata buffer on the rear left has failed,
Dec 02, 2012 | Televison & Video
Sanyo DP46848 has sound but no picture.
Tv turn now,have a flashes of picture a few sec.than dies have sound left only?Yes,than ur tv have a 2 long boards are dead that call LCD inverter boards.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Dec 07, 2010 | Sanyo DP46848 LCD TV
I cracked the inside of the tv while moving, the screen itself is not cracked but the picture looks like a rainbow of ink is this repairable
I do not like give bad news but you describe a damaged panel, entire front screen unit, part if available is usually sold exchange(means old one cannot be damaged) if panel damaged it will cost more to replace than set did when new.
If you have any questions let me know, I am here to help.
Regards, SD TECH
Oct 25, 2010 | Sanyo DP46848 LCD TV
DP 446848 is going dark on left side and lower 75% of screen. What's up?
I am working on a solution and have some ideas but I need other people with the same problem to help me by trying some things for me. If you are interested in helping email me at jrwblueyes1@yahoo.com. JR
Sep 17, 2010 | Sanyo DP46848 LCD TV
Sanyo 46 IN. tv DP46848. The left 1/3 of screen is dark
It is a common problem for this model of a Sanyo TV, it uses a Samsung or Chime LCD panel.
The problem is the data buffer IC soldered on the flat flex cable between the LCD panel & the buffer board that gets damaged or loose soldering. If you be able to fix yourself, you may find some videos on YouTube, it will show you how to fix the buffer problem.
Jun 01, 2017 | Sanyo Televison & Video
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
Hi there ui have an old sanyo TV no idea what model it is BUT it was working fine this morning wen i left for work. came home and now its stuck in standby? and idea what this could b? u hear the speakers...
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 10, 2009 | Televison & Video
Televison & Video Logo
209 people viewed this question
Top Televison & Video Experts
