Question about Daewoo DWR-WE33WS 7.3 Cu. ft. Capacity Electric Dryer 11 Cycles
DAEWOO DRYER DWR-WE33WS DOESN'T HEAT - Daewoo DWR-WE33WS 7.3 Cu. ft. Capacity Electric Dryer 11 Cycles
2 Suggested Answers
SOURCE: Fro a couple of weeks now Daewoo dryer DWR-WE32WS
Sounds like your thermostat controller and or temperature sensor has failed, that, or it is the main Controller board, or both/all. Or it's an Element that's faulty. One must work through the troubleshooting procedures to isolate and then remedy the issue.
http://www.eserviceinfo.com/repair_tips_database/Daewoo_001.html
Above is a link for a manual.
http://www.acmehowto.com/howto/appliance/dryergoe.php
DIY website above.
Posted on Mar 06, 2011
How to take appart a daewoo m# dwrwe5413rc
Daewoo DWR WE5413RC Manuals
Not sure if this helps or not, but there is the manual link.
Jan 07, 2015 | Daewoo Cars & Trucks
Why does My dryer make a noise when it starts and stops? It also makes some sounds when it is running
how long have you been using the dryer? seems to me you might have issue with the razor or the drive belt. you might want to get a professional to have a look at it.
May 27, 2014 | Daewoo DWR-WE5413 7.3 Cu. Ft Capacity...
No heat in dryer
O NA SECADORA DAEWOOO MODELO DWR-WE33WS QUE NO CLIENTA
Apr 12, 2014 | Daewoo Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
I have a daewoo dwr-we3011rr dryer and want to be sure my heating element is bad and not another issue. dryer turns on and tumbles fine but has no heat.
Try to find someone who has an ohm-meter or a multi-meter and can take your machine apart and test the heating element. One that is working should show continuity through the element., One with a blown element should show no current flow through the element.
Be blessed.
Sep 23, 2013 | Daewoo Dwrwe3011ww Dwrwe3011ww Front Load...
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
DWR-WE33WS
either the heat coils or the fuse
Jul 30, 2012 | Cars & Trucks
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
Hi I have a GE Profile DPGT750GC gas dryer and it doesn't heat. I've had this model for a few years and it worked fine until about last year. The drying wasn't good at times but didn't...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 11, 2011 | Dryers
We have the DWR - WE32WS Electric Front Load Dryer by Daewoo. Had to replace the heating element but forgot to mark the wires. Anyone know which colours go with what or how we can find out? Thanks
Ive got a question on your question -- where did you get the element from?
I've been trying to get a hold on one from all sorts of online sites, but none of them seem to have it in stock.
I might be able to open the back of mine and take a pic of the wiring
Sep 26, 2010 | Dryers
Daewoo DWR-WE33WS 7.3 Cu. ft. Capacity Electric Dryer 11 Cycles Logo
125 people viewed this question
Top Daewoo Dryers Experts
Andrew Taylor
Andrew Taylor
David Ellis Rhea
Mai Lor
Are you a Daewoo Dryer Expert? Answer questions, earn points and help others
