Question about GE 25840GE3 Cordless Phone
MI TELEFONO NO TRABAJA EL CALLER ID
NO DETECTA EL IDENTIFICADOR DE LLAMADAS YA ESTA ACTIVADO EL SERVICIO EN LA LA OPERADORA
5 Suggested Answers
SOURCE: Tengo telefono GE modelo 27831 x 2 y uno de ellos no funciona
La solucion es super sencilla, simplemente debe poner el auricular auxiliar en la base principal durante 10 segundos y luego ya va a funncionar, por que es la base la que que debe identificar el teléfono, ya que la base auxiliar solo es un cargador.
Saludos...
Posted on May 06, 2009
bbl242003
  • 1637 Answers
SOURCE: HOLA, NECESITO VER SI ME
You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 19, 2011
SOURCE: nececito el valor de la resistencia r5 ya que
necesito el valor de la resistencia r5 ya que ?sta se encuentra quemada y el tel?fono no enciende gracias flora e-mail: facy5@yahoo.es
Posted on Apr 06, 2011
  • 76 Answers
SOURCE: TENGO UN TELEFONO INALAMBRICO GENERAL
what are sida for any qustion for my face book problemme for any thing as
Posted on Jun 23, 2011
Mi ford focus presenta el error de codigo p0193 que debo hacer xq ya se sustituyo la pila de la bomba de gasolina
El codigo P0193 se refiere al sensor de presion del riel de inyectores, Hay que probar la presion y medir el voltaje en el sensor del riel pin 1 y no debe ser mayor a 2.98 voltios para 42 psi de presion, si la presion esta bien y el voltaje es diferente cambie el sensor, pero tenga en cuenta que el trabaja en serie con el potenciometro del pedal del acelerador y este ultimo podria estar defectuoso, verifique el pedal del acelerador
Sep 07, 2012 | 2006 Ford Focus
Yo mande mas de 10 mensaje de numero celular 584123362473 y 04125516627 y no me an dado ningun credito, por ejemplo:gracias, facebook le cobro 5.80vef a su cuenta de telefono. codigo...
compre token por zong mande 3 mensajes solicitando 121 token por zong me cobraron los msj y nunca me llego el codigo ni los tokens mi numero es 04268104327 de venezuela me mandaronun mensaje de zong discurpe por la compra contactar a support.vzzong.com y no consigo la pagina :S
Aug 19, 2011 | zong.com
Compre una bateria nueva para mi motorola A1200i y al cabo de una semana ya no funciono me figura bateria invalida. La bateria que compre es original tal cual tenia mi celu. Agradesco su ayuda
Hola.
Para empezar si la bateria es original, deberia de tener algo de garantia. Intente llamar el vendedor para consequir un reemplazo.
Si el telefono funde la bateria, entonces tienes un cargador defectuoso o un contacto interno en el telefono. Pida otra bateria y Intente utilizar un cargador diferente. Si la nueva bateria se estropea otra vez, entonces es el telefono que esta estropeado.
Suerte.
Ginko.
Mar 10, 2011 | Motorola Mobility MING A1210 Cell Phone
Ayudame con mi phone E71 pro Qwerty
Para que conpania es el telefono? Y cual es tu compania de telefono? Si te esta diciendo que solo puedes aser llamades de emergencia es porque no sirve con las SIM cards que le estas poniendo o no tiene senal.
www.usedcellphoneshop.com
May 24, 2010 | Nokia E71 Smartphone
Falla nokia 5530 al responder o hacer llamadas
buen dia a mi me pasa igual y me dijeron una mala noticia. tiene un corto. me ddijeron q lo tienen q soldar y queda commo nuevo eso si, me cobran 500 pesos mex. pero ojo hay algunos sitios q te dicen q se la juegan que puede darse el caso q quede brickeado osea q se quede como labrillo o pisapapeles.sniff no tengo cash para arreglar el mio. waaaaa. eso se debe a q falla ese modelo de la nada. eso me explicaron.
Mar 04, 2010 | Nokia 5530 XpressMusic Smartphone
Localizar transmission speed sensor en una chevy silverado 2005
Yo speek español muy pequeño, pero había una memoria de servicio en el racimo de instrumento. El velocímetro sólo deja de trabajar. Entonces esto puede no ser el sensor de velocidad, pero el racimo de instrumento. La velocidad senor es localizada en el alojamiento de cola de la transmisión. El muy trasero. Usé translater en línea entonces espero esta leva rito. Bien buena suerte.
Jan 10, 2010 | 2004 Chevrolet Silverado 1500 Crew Cab
MI PROBLEMA CONSISTE EN QUE ME HAN CAMBIADO TODA LA PLACA BASE Y SIGUE EL MISMO PROBLEMA,QUE ES EL DE REINICIARSE DE CONTINUO.ESTAS HABLANDO POR TELEFONO Y SE CORTA Y SE REINICIA.¿SOLUCION?
Primero hazle un hard reset, no sin antes copiar todos tus datos en el pc. Despues de estoy viene como de fábrica, te aconsejaría flashearla con la rom oficial. Si lo sigue haciendo, en mi opinión es un cotacto de masa q esta mal, o la conexión con la batería, pero eso ya es mucho especular. Prueba las dos primeras a ver si tienes suerte. UN saludo!
Dec 16, 2009 | HTC P3300 Smartphone
Identificador de llamadas
Yo no conozco ese producto, pero te puedo ayudar si me identificas el manufacturero (fabricante) y el detalle del modelo. Es posible que ese manufacturero tenga instrucciones en espa?ol. Si no, puedo hacer la traducci?n al ingl?s. Estoy en Puerto Rico y soy bilingue,
Mar 26, 2017 | ATS 4121CCL Twin Cordless Phone
Call for service CD4 en estudio 650
CD4 indicates full toner bag, need to be disposed...
Mar 25, 2008 | Toshiba E-STUDIO 650 Copier
GE 25840GE3 Cordless Phone Logo
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
