Question about Dell Latitude E5520 Laptop Computer PC Notebook
E5520 no boot device found
Boot device found
3 Suggested Answers
Fixe_You
  • 1800 Answers
SOURCE: Cannot boot up Inspiron 8200
The configuration is the internal HDD is the Master on the Primary IDE bus, the fixed optical drive is the Slave on the Primary IDE bus, the Media Bay device is the Master on the Secondary IDE Bus. Pull the HDD and nothing will work.
The error occurs when either the HDD or optical drive becomes half connected to its connector. That locks up the bus and the BIOS reports both failed. Reseat one or both of the drives. The Inspiron cases flex too much because of the loose palm rest "feature"
plz give me a good feedback.
Posted on Feb 02, 2009
  • 73 Answers
SOURCE: Laptop won't boot.
If it used to start up OK, then the hard drive is probably broken and needs to be replaced.
If you're adding a new hard drive, it may need to be partitioned and formatted. Insert your Windows CD, and start up off that, and run the Windows setup. It will format and partition the drive for you.
Posted on Feb 08, 2009
HP 255 How do I setup bootable disk ? I have tried esc and seled internal cd-dvd room but it doesn't work
On the HP System, you'll need to press the escape key as the system is starting up, and then hit F9 to get to Boot Device Options. Once there, you can set the boot order. After you've set the boot order, you'll also need to make sure that you have bootable files in the device that you've selected as the first boot device.
For example, if you've set the first boot device as CD-ROM drive, and the second is the Hard Disk Drive, then you'll have to make sure that there's a bootable CD/DVD in the drive when you start the system. If no bootable files are found on the first boot device, it'll automatically check the next boot device, which is the Hard disk and start booting from the Hard disk.
GuruAid
May 18, 2014 | Computers & Internet
Will not boot
hp Serial number 5CG2452DY3
Product number c2n25ua
windows 8 will not boot . tried f11 says boot device not found. F8 and shift will not put in safe mode. F2 says smart check not found.
no boot disk.
I need help
Jan 03, 2014 | Cell Phones
Hp pavilion a530n will not boot for cd it says not hard drive found reboot and select proper boot device or insert boot media in selected boot device
Need to set it to boot onthe CD drive.To boot on CD drive;
1-at start up press F2
2-At BIOS select BOOT option and move the CD drive to the fist option using the keyboard arrows.F10 to save and exit.
Oct 26, 2010 | HP Pavilion A530n (DW234A#ABA) PC Desktop
Boot from non Dell raid controller
Check the Boot Sequence again -- if there are any "SCSI" devices listed, enable them, and make your CD-ROM the "primary" boot-device (so that you can install Windows) and make this "SCSI" device the SECONDARY boot-device, and disable the internal hard-drive, so that it won't be used as a boot-device.
Dec 27, 2009 | Dell Computers & Internet
Gateway mx6453 wont boot up- oper system not found
Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
if you get msg opperating system not found use the system restore disk
Hope This Helps good luck
Please leave feedback
Nov 26, 2009 | Gateway MX6453 Notebook
Intermittent failure to boot up does not detect
hi.. have some idea on that... when you try to format your computer.. pls make the SATA as "first boot" or "second boot" then try to boot again your computer.. thank you very much...
Jul 08, 2009 | Biostar G31-M7 TE Motherboard
Dell Latitude E5520 Laptop Computer PC Notebook Logo
74 people viewed this question
Alun Cox
