Question about Leviton Hardware & Accessories
Leviton VPT24-1PZ Need clear instructions on how to program timer
SOURCE: Looking for the instruction manual for Leviton timer model 6651-I
6651 manual online here: http://www.smarthome-products.com/productspecs/DI-000-06651-22C.pdf
Posted on Mar 11, 2010
SOURCE: How can I program my Leviton timer model 6651-I?
Leviton 6651 Manual.
http://waterheatertimer.org/pdf/Leviton-6651-manual.pdf
Timer requires a battery which should be replaced each 12 to 18 months.
Timer replaces single-pole or 3-way switch, and does not need a separate neutral wire.
Timer is for incandescent lights only.
500 Watt capacity
Push the door for manual override to reverse program that is in effect.
The 14 hour timing period is represented by 24 dip switches.
Each dip switch is positioned for ON or OFF.
Click the dip switch right or left
Start at the bottom
For example: ON for 3 hours, OFF for 4 hours, ON again for 3 hours:
Click dip switches 1 thru 3 to ON position, 4 thru 7 to OFF position, 8 thru 10 to ON position
ON position is to the right.
OFF position is to the left.
At the end of the 14 hour program, the timer turns lights OFF until the original start time is reached after 24 hours.
Timer will operate like this while in AUTO mode, until function switch is moved from AUTO to MAN or OFF modes.
Function switch is located at very bottom of timer door.
To activate program (on first day), function switch is set to OFF position for 2 seconds, and then move function switch to AUTO mode, and programming cycle begins.
Posted on Nov 12, 2010
SOURCE: having a hard time programming
I cannot tell which timer you have.
Your instructions show model number which will exactly identify your timer.
I have extensive files on timers if you can identify your timer, for example describe the buttons on timer and if timer plugs into wall or is wired in place of a switch or if timer is inside large plastic or metal box.
Check links below to help identify your timer, and then add a comment, and I will help further:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
http://waterheatertimer.org/UPM-timers-and-manuals.html
It would be helpful if you described exactly where the programming steps are difficult.
Most timers follow same general pattern for programming, but each offers slightly different options.
Some timers are tricky to program. Again I have files to assist you.
You can also take advantage of Fixya phone service where expert speaks to you on the phone for a price.
Posted on Dec 21, 2010
SOURCE: Lost programming instructions and need
Open following link to identify timer and download manual
http://waterheatertimer.org/Aube-timers.html
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jun 06, 2011
greg_nelson1
SOURCE: programing instructions
you can look here http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=6124H-I&section=44955&minisite=10251 and click the adobe manual for programming instructions.
Posted on May 05, 2012
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Programing instructions
May 05, 2012 | Leviton 6124H 24 Hour LCD Programmable...
Change program leviton timer
Copy following link to identify Leviton timer and download manual
http://waterheatertimer.org/Leviton-timers-and-manuals.html
May 02, 2012 | Leviton 1000W / 20A 1HP-120V - 6230M-A -...
HOW TO RESET TIME
6124 is 24-hour timer single-pole timer
Open following link for images, instruction manual, ez set instructions, and wiring instructions
http://waterheatertimer.org/Leviton-timers.html
Apr 18, 2011 | Leviton 6124H 24 Hour LCD Programmable...
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Dec 02, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Need instructions to set my timer. Where can I find these?
If this is not your timer, add a comment.
Also see Leviton timers at:
Leviton 6124 manual
Wiring for 6124 timer:
Add a comment if you need help wiring this timer
Nov 30, 2010 | Leviton 24-Hour LCD Programmable Timer,...
500 Watt capacity
Start at the bottom
Nov 11, 2010 | Solar Leviton 6651 Decora Programmable...
How do i program the LEVITON Decora Timer Light Switch 10/24hrs.
From this website you can download a free instruction sheet in PDF format...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=6216&section=17138
May 12, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Apr 12, 2009 | Solar Leviton 6651 Decora Programmable...
Hardware & Accessories Logo
85 people viewed this question
Top Leviton Hardware & Accessories Experts
Hippy_dd
Gene Haynes
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
