Question about Moultrie MFH-DGS-200 Digital Camera
Moultrie D-55irxt says sd card locked on - Moultrie MFH-DGS-200 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Moultrie Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Sep 20, 2014
SOURCE: sd locking
I had this problem also. To solve the problem I blew into the slot where the card goes and it then read the card. If dirt gets into the port it causes the sd card to lock. You may have to use a pressurized can of eletronic spray to clean the port.
It worked for me.
Posted on Mar 04, 2009
  • 3287 Answers
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Posted on Oct 20, 2009
  • 296 Answers
SOURCE: moultrie DGW-100 won't read sd card
check small switch on side of SD card; should be pushed toward contacts.Using the USB cable provided with cam, PC SHOULD RECOGNIZE DEVICE...might have to go thru windows explorer to find it, then use windows media player, or other, to open.
You are running 98 or later, right?
Posted on Feb 17, 2010
  • 296 Answers
SOURCE: moultrie d40 locks up when I put the sd card in???
make sure card lock switch is forward toward contact strips fully.
Posted on Feb 20, 2010
SOURCE: SD card Locked
I have the same issue . . . tried new card, older card, 4 different cards, turned off camera, took out battery. I'm bummed.
Posted on Oct 16, 2011
Can you use rechargeable batteries to save on the cost of the batteries
You can in several type of equipment, but be aware that AA rechargeables are 1.2 volts instead of 1.5 volt of regular alkaline batteries.
May 30, 2017 | Moultrie Cameras
What does card lock mean on display ?
The SD card has the lock tab activated! Slide the lock tab off!
Jan 01, 2015 | Moultrie D-55IRXT Game Camera
Moultrie game camera
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 09, 2013 | Cameras
Trail Card Lock
May 12, 2013 | Moultrie Game Spy D-55IRxt Game Camera
Why does my camra say trail card lock on it and willnot take pictyres
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 27, 2012 | Moultrie D-55IRXT Game Camera
Moultrie MFH-DGS-200 .... says SD Card Locked on
ck postion of switch on side of SD card...should be pushed toward contacts
Oct 23, 2009 | Moultrie MFH-DGS-200 Digital Camera
Moultrie GameSpy 4.0 states SD Card is locked when it is open. How can this be repaired.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jun 16, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Sd locking
It worked for me.
Dec 24, 2008 | Moultrie MFH-DGS-200 Digital Camera
Moultrie MFH-DGS-200 Digital Camera Logo
209 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
