Question about Hitachi 60FX20B 60" Rear Projection Television
Whats the causes of piture fading to black in Hitachi 60FX20b projection tv
It does it sometimes in 2-3 hours, somtimes in 2 minutes
techman
  • 3130 Answers
SOURCE: Hitachi 60FX20B
If you hear the unit comming on and theres no sound or Picture, then theres a fault in the horizontal sweep/HI Voltage circuit. This should not be fooled with unless you know the safty issues with HI voltage as theres voltage in these sets even after they are unplgged for a while. Good Luck
Posted on Jul 06, 2006
tvtek
  • 1284 Answers
SOURCE: My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Posted on Feb 01, 2007
  • 58 Answers
SOURCE: 53FDX01B Picture went black
is the screen lit up?
If so the video module is bad.
replace the surface mount caps app. 8 to 10
or replace module
guy9
Posted on Jun 10, 2008
SOURCE: My hitachi tv keep turning off after 5 minuted of
I just got done putting my panasonic 50 projection back together. There is a thermal cut off relay on top of your bulb box, can normally be seen after removing the back of the tv. With the tv unplugged make sure the area around this relay is clean of dust. If the simple fix dosn't work make sure your cooling fan is coming on with the tv.
Kevin
Posted on Oct 29, 2009
SOURCE: Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Posted on Dec 30, 2009
Hitachi 60FX20B
Shop repair and very unlikely to get fixed in home
Aug 28, 2012 | Hitachi 60FX20B 60" Rear Projection...
Hitachi tv 60v710 turns off and on by its self every minute what it can be?
This problems it is related to the tv projection lamp.The tv projection lamp is inside the tv now.Been in the tv like a 1 1/2 or 2 years already?Tv is on and used it like 4 or 5 hours daily?Yes,than the tv projection lamp must be replaced should solved this problems.If the tv projection lamp already been replaced,than this problems are caused by the board that call the Ballast board.This Ballast board only job are to ignite the tv projection lamp only.
Jul 13, 2011 | Hitachi 60V710 60" Rear Projection HDTV
I have an Hitachi 60FX20B, there is a doubel image om the top half of the picture. The doulbe image is slanted at an angle. Any ideas?
Please replace two big black convergence output ICs in tv to solve this issue, soldering work is required to replace them and local tv repair shop will do that job if you are not familiar with doing so.
Required ICs are available in PartStore.com
Hope this will help.
Thanks.
May 11, 2011 | Hitachi 60FX20B 60" Rear Projection...
Hitachi Model #51f59J The TV will turn on were it
http://gethuman.com/phone-number/Hitachi
Aug 13, 2010 | Hitachi 51F59 51" HDTV Projection...
Re-gas plasma tv were can i buy it from
hi i hav a problem with my tv.if i switch it on i have a black screen dats fades away after a while with small black dots on the screen but da piture is clear
May 26, 2010 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
Blue and yellow shadows
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 15, 2007 | Hitachi 60FX20B 60" Rear Projection...
Hitachi 60FX20B
Jul 06, 2006 | Hitachi 60FX20B 60" Rear Projection...
Hitachi 60FX20B 60" Rear Projection Television Logo
16 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
