Question about RCA PHD42600 42 in. Plasma Television
I need a new red "gun" for RCA 52 projection TV?
model MM52110JX2
    Sergeant:
  • 227 Answers
Might try MCM Electronics 1-800-543-4330. www.mcmelectronics.com
Posted on Jan 11, 2009
My RCA 52" projection TV
Try these companys PTS 1-800-844-7871
Encompass Parts 1-800-638-3328
UED 1-800-648-6657
Go to website at Encompass and type in your model number fior list of Parts/Prices
Jun 23, 2011 | Panasonic PT-47WX53 47" Rear Projection...
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
No color on tv screen
Repalce your tubes they are bad Red,blue,and the Green.
Dec 19, 2008 | RCA Televison & Video
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
RED LINES
Your red CRT socket may be loose or have cracked solder if not, try turning down the red gun screen control inside the set just a little. Youre experienceing what is known as retrace lines
Jan 21, 2008 | RCA P52771AT 52" Rear Projection...
Rca guide plus gold 52 in projection tv
sounds like the blue CRT is contaminated open the back turn on the tv look into the blue gun if it looks snotty the coolent needs to be replaced
Oct 31, 2007 | RCA P52926 52" Rear Projection Television
52 in RCA
The T.V. has no lamp, it has 3 guns red,blue,& green. Unplug the lead that goes to the high voltage splitter(make sure t.v. is unplug). Then turn the t.v. back on if you hear the H.V. lead making a hissing sound continuously most likely the h.v. block needs to be replaced. Follow the lead from the flyback to the h.v. splitter, this will be the lead that unplugs at the splitter.
Oct 11, 2007 | RCA P52926 52" Rear Projection Television
RCA PHD42600 42 in. Plasma Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
