Question about Video Cameras
Doesnt read the memory stick
I have a 8g memory in it but it still says no media insert a memory stick
  • ichigo_ishir
    ichigo_ishir Dec 04, 2012
    sony handy cam DCR-sx40
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Video Cameras Master
  • 102,366 Answers
What make and model camcorder?
Posted on Dec 04, 2012
  • ichigo_ishir
    sony handycam DCR-sx40
Doesnt read memory stick
Try formatting memory card as different devices allocate admin files in order to manage your photo files. That should fix ur problem.
Dec 04, 2012 | Sony DCR-SX40 4GB HANDYCAM PAL CAMCORDER
Sony Cyber Shot DSC-H9
The camera may display a MEMORY STICK ERROR or C:13:xx message (xx can be any random number) on the LCD screen for the following reasons:
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Remove and re-insert the Memory Stick® media several times.
  2. The inserted Memory Stick media is not compatible with the camera. Check your instruction manual for information regarding Memory Stick media compatibility.
  3. The inserted Memory Stick media is not formatted. Format the Memory Stick media using the FORMAT option in the camera menu. WARNING: There is a risk of data loss. Formatting will erase all stored data, images, movies, etc., from the Memory Stick media.
  4. The terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
  5. The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
Thanks
Proton
Oct 02, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
My 8gb memory stick only reads 4gb
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
if still no joy
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps you
Apr 17, 2012 | Sony Electronics - Others
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
8g sd card doesnt work on jvc camcorder...it says card error
Each camera have maximum memory card to be readable. If the memory capacity is to high from the limit, the camera will hard to write the data inside the card and said that "card error".
Try to insert memory card with lower capacity (4 or 2 GB) and read the user manual to know optimum memory card for your device.
Hope this help and RATE please !
Jan 16, 2011 | Cameras
Camera can no longer read the Sony 16G Memory Stick Pro Duo
Sorry but it sounds like the card is pootched. Very common problem with these sticks. Best bet is to get multiple 2gb sticks to ensure that when one goes (and one will) you won't lose all of your pics
Sep 15, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Format error in a new dsc-s780. Formatting the 8G card does not solve the problem
I am not sure that it accepts 8gb cards
but at least try this:-
If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it there then retry the stick in the camera. if you cannot format the stick it is very possible it is bad.
Aug 14, 2009 | Cameras
I put a 8g card in and it wont read it.
The card is to big to be read by the player. The highest amount that the memory card reader on the mp3 player can read is 2gb. So you will need something smaller for the player to read it up to a 2gb memory stick. Anything more cant be read as it is too much for the player.
Aug 06, 2009 | SanDisk Sansa e250 MP3 Player
LG SHINE MUSIC PROBLEMS!
I bought 8G memory card for my LG Shine Cell Phone and do not know hot to download music to it to be able to use it in my phone. Please help.....
Jul 04, 2009 | LG Shine KE970 Cellular Phone
8G memory card
you bought a fake memory stick. return it.
Jul 19, 2008 | Sony PlayStation Portable (PSP) Console
Video Cameras Logo
29 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
