Question about Sony Audio Players & Recorders
MANUAL SONY STR-KM7000
I NEED MANUAL THIS RECEIVER
SOURCE: Sony STR DG 510 receiver manual
Hey there, found it on the sony site...
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=STRDG510
Hope that helps.
Posted on Oct 19, 2007
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
SOURCE: left channel is out sony STR-D511
Had the same problem but found simple solution. I just reconnected the speakers which were on "A" connections to the "B" set of connectors immediately below - problem solved!
Hope this works for you.
Stuart
Posted on Jan 22, 2009
mlapres
  • 757 Answers
SOURCE: Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Posted on Jan 18, 2010
Testimonial: "Thank you excellent report spot on with the hook-up. Will buy new receiver. John McMullan."
adracamas
  • 344 Answers
SOURCE: I NEED TO RESET Sony STR D365 Receiver BACK TO
I believe what you want to do is as follows. Turn off the power supply. Hold the buttons 6, 7, 8. And turn on the power. The display should activate all options, then turn on and off a few times and finally display End. Then the memory should be reset back to Factory.
Posted on Apr 11, 2011
Bought a used sony str de845 with rm adu007, need program manual for rm.
If the remote is functionally the same as the original RM-LP204
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
Apr 11, 2011 | Sony STR-DE845 Receiver
Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Sep 15, 2009 | Sony STR-DE845 Receiver
Need instruction on how to set up to surround sound.
Go to www.sonystyle.com click on "support" Type in your model # and you will get more information the you could ever need on that receiver! Including the manual. Hope this helps!
May 22, 2009 | Sony STR-DE697 Receiver
Sony receiver STR-GA8ES
You can download required service manual from Manual Zone for small fee.
You can buy required parts for the same unit from Part Store.
Jan 18, 2009 | Sony STR-GA8ES Receiver
275 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
