Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Would not start
Stihl 180 , used for few days in 2004 ( year of purchase) with occasional diffic. starting then + serviced & reassured ; not used again until Dec.2008; while cutting a tree unable to restart; serviced again: everything OK apart from the crank case (engine) which was not opened but advised that probably the engine is at fault + would not be ECONOMICAL to repair. What should I do? ( the original price was AUD 500 )
    Problem Solver:
  • 7 Answers
The first thing I would do is remove the spark plug and watch it when you pull the start cord. If it sparks, you will know the problem is in the fuel intake. Check all the parts and clean them with some denatured alcohol.
Good Luck!
Ben
Posted on Jan 12, 2009
My o34 Stihl chain saw ran good one day the next day won’t start I rebuilt cab got fire no start I tried starting fluid in plug still no pop to try to start saw is 34 years old well maintained
Have you checked the compression on the cyl. A saw that old may have lost compression and also have you checked the muffler to be sure it is not plugged. I base this on you saying you have fire to the plug.
Oct 08, 2017 | Stihl Garden
Part # for spark plug wire on stihl saw model ms 180 c
spark plug wires on small engines are normally part of the coil so you may have to get a new coil pack
talk with stihl service parts or service shop
Jul 30, 2016 | Stihl Garden
Stihl 180c runs wide open all the time.it has a new carb on it, linkage is fine
Stihl MS 180C Wont Run ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
Aug 14, 2011 - 10 posts - ‎7 authors
I have a Stihl MS 180C that i cannot get to run. I used it all last year and went to use it a few months ago and it didnt seem ... it is not under warranty and i have pulled and pulled with choke on and throttle wide open and still wont start. ... Depending on the carb, some times you can just go for broke and get a ... Stihl ms 180 running rich
Jun 5, 2015
Echo cs-370, they actually work
Oct 12, 2010
More results from www.arboristsite.com
Stihl Chainsaw Troubleshooting Guide · TEK Indoor · Disqus
https://disqus.com/home/discussion/tekindoor/stihl_chainsaw.../newest/
Stihl
Dec 15, 2015 | Stihl Garden
Yamaha xc180 no spark
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
1984 Yamaha Riva 180 been sitting for 8 years won start General Dirt Bike...
Yamaha Riva 180 washed now no spark
http://www.motorscooterguide.net/Manuals/Yamaha_XC180_Service_Manual.pdf
OEM parts for Yamaha
Yamaha Owner Manuals
Sep 29, 2013 | 2004 Yamaha DT 125 R
Stihl MM 55 won't run/start
You will have to have extremely clean fuel with stihl carbs. As the orifices are extremely small some are so small you can barely get human hair through them. So make sure you are using correct mixture if it says 50-1 u better make sure you use 50-1. Also make sure the can has no trash of any kind. And main thing make sure the fuel filter is in place and not at all damaged.
Aug 05, 2017 | Stihl Garden
I have a homelite 33 cc bandit cannot get carb tuned. And have hard time Getting it started when it does start it runs wife open what Tools do I need to adjust carb
It is more likely that you have a problem with a sticky check valve in the carburetor. I recommend sticking it in a $20 jewelry cleaner for 10 min and replacing any cracked or rotted hoses. this machine is meant for 50-75 hours of use. Stihl and a few other brands still make machines meant for years of service. Aside from this switch over to a ethanol free fuel which you can purchase at stores like www.arcolawn.com Good luck Joe
Feb 10, 2011 | Garden
How to start stihl ms 180 c
pull choke full on pump petrol 5 to10 times it should try to start take throtle of full to next button and try again
Jul 17, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
What is the oil/gas ratio for this model chainsaw? I left my manual at our previous address. Thanks
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Nov 15, 2009 | Homelite Garden
New Stihl ms 180 idles but will not accelerate
sounds like you may have a broken throttle cable. take the top cover off and inspect to see if this is the problem. let me know if this is it or if you need more assistance with this.
Mar 01, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
70 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
