Question about The Biggest Loser SLIMCOACH by MYTRAK
My MyTrak won't work
I keep trying to sync both mine and my daughters slimcoaches and neither will work. Either the message says it is timed-out or it just freezes
Unable to install The Biggest Loser SLIMCOACH powered by MYTRAK
Did you ever get a response from this or find the software ANYWHERE?
Mar 11, 2014 | The Biggest Loser SLIMCOACH by MYTRAK
Time synchronization not working
In thinking about this, we need to first consider what is different about those systems which gain 3 minutes from those which do not. It is obvious to me that since the auto-sync is the problem and the manual sync works, it is not that the system isn't automatically syncing to the right server, but not really syncing at all....so therefore their must be something wrong with the auto-sync.
Given that I would suggest you read http://www.thewindowsclub.com/windows-time-service-not-working-synchronization-fails-error
which, while not specifically addressing your problem gives you several palaces to look and compare the working versus non-working systems.
Jul 24, 2013 | Microsoft XP Computers & Internet
My daughter 2004 Kia won't hold a battery charge.
voltage regulator. it may be in the alternator, or remote mounted. ((the alternator can be charging, but if voltage regulator is'nt working then it won't allow voltage to get back to the battery to keep it charged
Sep 07, 2012 | Cars & Trucks
My zte won't send any text messages because of shortage of numbers
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Aug 13, 2012 | ZTE Warp
Bought a new remote because i lost mine and it won't work
i bought a logitech / harmony univercial remote and it is unreal you sync it on your computor it is realy easy and very effective, has a huge range of devices , costs about 30 dollas
Jun 06, 2012 | Electrolux FRIGIDAIRE LRA074AT7 6500BTU...
It wont load says loading hangouts 64%
Exactly the same happened to me. It either says connecting to server 16% or loading hangouts 64%. Sometimes refreshing the page can help (F5) but other times it won't work. I left mine loading all day and it still didn't work. I'm afraid that there is nothing you can do about it just keep trying in hope that it will eventually work. That's what I did. I hope this was helpfull!
Oct 23, 2011 | Facebook Apps
Cant get songs onto ipod shuffle.(daughter has ipod touch)
When you go into the ipod section on iTunes, click the music tab, make sure 'sync music' is checked and 'selected playlists:' is also, then check the playlist you want to use. Click 'sync' button
If that don't work go back to the summary tab and hit 'restore' and follow the instructions to reset the ipod, resync and all should be fine.
All the best
Sean
PiDigital
Dec 31, 2008 | Apple iPod shuffle Second Gen. Silver (1...
The Biggest Loser SLIMCOACH by MYTRAK Logo
97 people viewed this question
Top The Biggest Loser Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a The Biggest Loser Exercise and Fitnes Expert? Answer questions, earn points and help others
