Question about GE AGM24DJ Electronic Room Air Conditioner
Air condition won't work
My air condition worked for for a short time?2 occasions since I purchased it the begining of June. Wehn I turned on last night using the remote control it would only emit a clicking noise. I unplugged it checked the reset button on the air conditioner plug and plugged the air conditioner back in and the clicking continued. The air conditioner never came on.
  • 1 more comment
  • martin weiss Jun 08, 2007
    Hope you can help
  • Anonymous Feb 21, 2008
    haier
  • Anonymous Mar 31, 2014
    How to set timer using remote control in hitachi window air conditioner
  • 80 Answers
THE CLICKING SOUND IS A RELAY PULLING IN ITS LIKE A SWITCH CONNECTING TWO WIRES. THIS IS A GOOD SOUND BUT IS USALLY FOLLOWED BY SOMETHING COMING ON FAN ETC... CHECK TO SEE IF YOUR UNIT HAS AN LED LIGHT ON IT AND HOW MANY TIMES IF ANY DOES IT BLINK?
Posted on Jan 14, 2008
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
The last time we used the machine worked fine. Now when we try to use the machine, it won't start. It will turn over a little, but that's it. We have tried on several occasions to get it started...
Make sure the fuel is fresh (not older than 30 days). Never use old fuel unless it has an additive such as "Stabil" in it. Remove and clean or replace the spark plug. Make sure it is getting spark. With the plug out, shoot a couple good shots of carb/choke aerosol cleaner into the engine. Reinstall plug immediately. Choke it and try to start it. If you can get it running that way, the normal fuel flow through the carburetor may resume. Any other number of things could be wrong, but the machine has to have 1. Compression 2. Clean Fresh Fuel 3. Clean Air 4. Strong Spark (blue color). Mostly, the problem with these is a fuel supply problem, which consists of the fuel filter, fuel lines, internal parts of the carburetor and condition of ALL sealing gaskets on the engine. Any air leak will result in a no start condition. There is no majic fix. The ethanol in the gas now wrecks havoc on these little machines. Check all the above. Try the carb cleaner and post back with results.
Jul 01, 2011 | McCulloch Mosquito 86 Mcculloch 25cc...
Switched from manual to Honeywell rth230b. It was working fine until yesterday. We had it since last June. AC worked all last summer and Heating during winter. The AC was working this year too until...
I will assume this is a central air conditioning system. From what you tell us about the symptoms a few things come to mind for you to check.
1. Change your thermostat and see if that cures your problem.
*The following steps requires the use of a multimeter and work around electricity, use due caution or call a professional.*
2. Check the contactor inside the outside unit while you have the thermostat calling for cool and see if it is pulled in or if it is stuck. If you are not comfortable around high amp electricity then please call a professional in your area to make these checks.
3. Check to see if the thermostat wires going to the outside unit are sending 24 to 28 volts to the unit. This will tell you if the problem is outside or inside the home. If there is no voltage there then check at your furnace to see if the t-stat is sending the power on the Y connection.
There is much more to check but this should get you going in the right direction and will locate the problem in most cases.
Hope this helps.
Jun 14, 2011 | Heating & Cooling
Fuji Finepix 470batteries only last a very short time. Previously
Most of time it is a battery problem.... try with another battery, before purchasing new one....
If another battery does not works then get it serviced.
Battery has certain time period life (mostly it is expressed in, "no. of times charge") after that battery power deteriorates...
Or if battery has been water clogged then also battery power deteriorates.... (for water clogging may happens exposure of battery to humid conditions)
Please rate the answer if you find it useful...
thanks for rating....
Apr 29, 2010 | Fuji FinePix 4700 Zoom Digital Camera
Lens won't clear up grey tell me to remove the cap
On the jvc digtal video camera GR-D30 there is a recall problem is lens cap message
on but the cap is off but the lens is still grey shipping the camera back no charge
the jvc support information number. i call
Apr 28, 2009 | Cameras
Power windows won t work
MY POWER WINDOWS WOULD WORK AND THEN NOT WORK, IT SEEMED TO BE WHEN I WOULD SHUT THE DOOOR THEN THEY WOULD WORK, THEN CLOSE THE DOOR AGAIN AND THEN THEY WOULD QUIT AGAIN. THEY ALL STOPPED WORKING AT THE SAME TIME, IT SEEMS TO HAVE SOMETHING TO DO WITH THE DRIVERS SIDE DOOR. NOW THEY WON'T WORK AT ALL.
Apr 15, 2009 | 1995 Jeep Grand Cherokee
GE AGM24DJ Electronic Room Air Conditioner Logo
464 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
